06-15-2015, 02:24 PM | #1 |
69 GMC c15, leaf spring
I have a rear left broken leaf spring, does anyone have one or what can replace it. probably put on a set of them.
06-15-2015, 03:03 PM | #2 |
Re: 69 GMC c15, leaf spring
Have you looked at any of the squares springs?[73-87]. I have a line on a 72 GMC short bed for salvage, It probably has the leafs as it didn't look to be hard loaded just a regular truck. The leafs were standard on the GMC and optional on the Chevrolet. It was just backwards from the Chevrolet that had standard coils with optional leafs. Jim
06-15-2015, 03:44 PM | #3 |
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
11-04-2015, 11:01 PM | #4 |
What rear springs will fit this? I am dire need of help. thanks
11-05-2015, 09:20 AM | #5 |
The two wheel drive 69-72 trucks use 2 1/4" wide springs (except the Longhorn and probably the C30) while the squares use 2 1/2", so that is out.
Eaton-Detroit can build you stock replacement springs or you can get drop springs from places like Early Classic Enterprises. The other option is to find a parts truck with 2 1/4" leafs. C20 leafs will physically fit but have a higher spring rate and different ride height.
