06-15-2015, 02:32 PM | #1 |
255 or 265's on 15's....
So I am about to pull the trigger on a much needed new set of tires for my 78 lwb/ 1/2 ton. Currently it has what I believe to be factory ralleys...15 X8 and 15X7's...I am going with 295's on the rear and can not make up my mind whether to go with 255/60's or 265/50's up front. I don't want the front end riding high....but I also don't want too short of a sidewall...I would prefer a complimentary size to the 295's...I read elsewhere that the 265's shorter sidewall looked funny....
Any thoughts? |
06-15-2015, 08:32 PM | #2 |
Re: 255 or 265's on 15's....
If you're set on the 295/50's on 8" wheels out back, 265/50's would yield similar look on 7" fronts. Keep in mind those are short compared to OE sizes (that help fill the wheel well up).
06-15-2015, 09:08 PM | #3 |
Are you sure you have 7's and 8's!
Look like 6.5's and 7's to me. |
06-16-2015, 07:34 AM | #4 |
A 265 on a 7 inch wheel will probably wear the middle of the tread unless you keep the pressure down. Probably not a big deal since I see so many newer trucks with uneven wear on the tires. I have always been a stickler for even tire wear.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-16-2015, 01:37 PM | #5 |
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop Last edited by BigMike608; 06-16-2015 at 01:43 PM. |
06-25-2015, 09:25 PM | #6 |
Well guys I went with the 295/50 265/50 combo....thanks for your input.
http://smg.photobucket.com/user/CGTC...64638.jpg.html http://smg.photobucket.com/user/CGTC...0Pkwy.jpg.html http://smg.photobucket.com/user/CGTC...64612.jpg.html |
