Wheel Bearing Issue?
I have an 85 K10 4" lift on 33s. I noticed my right front tire moves in and out when you push it back and forth. The ball joints look fine so I figured it might be the wheel bearing even though it isn't making any noise. It looks like there are several bearings in the wheel/hub/spindle assembly. I can't find a kit to replace them all and should I be replacing them all? I don't know which one might be causing the issue. Anyone have any advice on where to buy the bearing kit and which ones to replace? Thanks
Re: Wheel Bearing Issue?
I just replaced my front wheel bearings on my 87' k20.
Its not too bad of a job, takes some time. There are 2 bearings in each side - you'll need a special socket to removed the spindle nuts (there are two of them, plus a special locking washer that is sandwiched between them). I bought new races and bearings from RockAuto - I think it was around $50 or so total plus shipping. You will also need a new seal for each hub. I also did new front rotors while I had it all apart, since they are behind the hub. And I put in new wheel studs, probably could have reused the old ones but new ones were not too much $$, so I did new. Also replaced the front brake hoses while it was apart. |
#3 | |
Then from there see if you get any noise or excessive movement. |
