06-15-2015, 05:04 PM | #1 |
What is the better way to clean up my hood hinges and latch?
I used a mix of electrolysis and Evaporust to clean up my hood latch bracket. It worked wonders and is now at the "paint stage."
I don't have any way to blast so that is out. Will electrolysis harm the springs in the hood latch? If I let the hood hinges and latch soak in Evaporust or Krud Kutter (phosphoric acid), need I worry about not being able to paint all parts later? |
06-15-2015, 08:08 PM | #2 |
Re: What is the better way to clean up my hood hinges and latch?
ttt
06-15-2015, 08:22 PM | #3 |
I disassembled my hinges, cleaned them with a wire brush, phosphoric acid and steel wool. I then painted them after rinsing with water and wiping with rubbing alcohol. I think you'll do fine as you suggest in your post. I don't see how the electrolysis would harm the springs.
06-15-2015, 08:25 PM | #4 |
OK, well good. My hinges are riveted together so I don't think I can take them apart.
The hood latch and hinges are awkward so it would be hard to paint all their inside pieces. Is that something to worry about? Do I just grease them well after the cleaning? |
06-15-2015, 09:16 PM | #5 | |
They are awkward, especially with the springs still installed. With the springs out, I was able to change the hinge position for each coat of paint to get all hidden surfaces painted. I stretched the springs using a chain and my engine hoist, painted them, and let them thoroughly dry in the stretched position before reinstalling them on the hinges. I did not do any disassembly on the hood latch. As I recall, I hung it from a wire and shot paint onto and into it at all angles. I used 30 weight non-detergent oil as the lubricant after installing them. |
06-15-2015, 10:55 PM | #6 | |
I'll put the hood latch into some evaporust tomorrow and begin electrolysis on the hood hinges. |
06-16-2015, 01:02 AM | #7 |
Carpe manana
Can send these to be phosphate coated (Parkerized) and will return looking and functioning like new...http://67-72chevytrucks.com/vboard/s...&postcount=114
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 06-16-2015 at 01:07 AM. Reason: added link |
06-16-2015, 07:50 AM | #8 | |
06-16-2015, 11:22 AM | #9 |
Carpe manana
If you can't find a local plater try Kaehr Coating in Albuquerque - good work good price. Other members have used this plater. This finish is factory correct, durable, and relatively inexpensive. You would not believe how nice re-finished bolts look and there is no paint or powdercoat to fail. Good luck. Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
06-16-2015, 11:57 AM | #10 |
Called and emailed for a quote. Thanks.
06-16-2015, 01:51 PM | #11 |
Carpe manana
You bet. You'll be more than pleased. There's a minimum order but that will do much if not all of what you need. I'd suggest door striker plates, hood hinges/latches, and a pile of OEM bolts. I may have my seat tracks done at some point. Send 'em as is greasy too. BTW- their zinc plating is very nice also: http://67-72chevytrucks.com/vboard/s...&postcount=208
06-16-2015, 07:49 PM | #12 |
If your hinges are worn heres another option: http://www.hoodhingerepair.com/
With mine i felt the rivits were not worn much but when i popped the hood release the hood would not lift so i just used some spray lube and it made a world of difference both for opening and hood adjustment..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
