Old 06-15-2015, 05:42 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Rad Mount Question
I have what looks like two sets of lower radiator mounts. A lower rear and an upper front on the same cross member. All riveted in as from the factory. Is that normal?
Old 06-15-2015, 06:27 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Rad Mount Question
A picture would help, but yes there is an upper and lower mount for the radiator.
Old 06-15-2015, 08:38 PM   #3
The Rocknrod
Moderator
Pics - Please forgive the butt ugly purple powdercoat, it will be changed. So why two sets of rad mounts?
Old 06-16-2015, 12:03 AM   #4
jtrichard
"So why two sets of rad mounts?"
JUST to f with your head LOL .... I would say someone changed the rad (and did a very nice rivet job) OR they screwed up at the plant when it was built
jtrichard is offline   Reply With Quote
Old 06-16-2015, 07:20 AM   #5
The Rocknrod
Moderator
So are the fronts are for a V8?
Old 06-16-2015, 08:31 AM   #6
1963c-10
1963c-10's Avatar
Yes, the larger saddles are for the v8. Have you looked underneath to verify they are all riveted in? Could have been added with carriage bolts by PO.
Odd though, never seen two sets mounted on one truck like that from the factory. Good thing is you have the saddles you want/need.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-16-2015, 08:39 AM   #7
The Rocknrod
Moderator
Yep they are rivets:
Old 06-16-2015, 08:55 AM   #8
1963c-10
1963c-10's Avatar
Definitely look like factory riveted. Interesting.....thanks for posting.
