06-15-2015, 11:14 PM | #1 |
Help - Stock Oil Pressure Gauge Fitting
I finally am getting my truck back on the road. When I removed the gauge cluster I disconnected the oil pressure line at the engine block and put a plug in the hole, so I could run the engine and be able to move the truck. Now I want to hook it back up and don't remember removing a fitting from the line to the block. Is there one that I lost? all I have at the engine side is a nut on the metal line. anyone have a picture?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
06-15-2015, 11:28 PM | #2 |
Re: Help - Stock Oil Pressure Gauge Fitting
looking from the back of my motor on the stand. It's that white cap.
06-15-2015, 11:39 PM | #3 | |
The Older Generation
You have misplaced the block adapter fitting as pictured in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=613238 The male end is 1/8" pipe thread and the line fitting (compression sleeve nut) screws into the other end. LockDoc
06-16-2015, 12:02 AM | #4 |
Thanks Lockdoc!!
That is exactly the answer I was looking for. Don't know how I misplaced the block adapter, but will try to find one. Maybe at ACE Hardware. I won't waste my time at AutoZone.
