Old 06-15-2015, 11:25 PM   #1
Mthumphrey
Mthumphrey's Avatar
Installing Edelbrock 500
I have a Chevy 250 that is pretty much stock. Looking to install a Clifford intake, headers and Edelbrock 500. Any tips I should keep in mind? This is my first time doing this install. Looks like I will need to install the carb sideways... Any thoughts would be appreciated.
Thanks!
Michael
Mthumphrey is offline   Reply With Quote
Old 06-15-2015, 11:58 PM   #2
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: Installing Edelbrock 500
Doesn't matter how you install the carb. I'm installing mine with the primaries aiming toward the radiator. Dynoing hasn't shown huge advantages or disadvantages on the carb mounting. Keep in mind you'll want a good HEI for that engine. Your now adding alot of fuel. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is online now   Reply With Quote
Old 06-16-2015, 01:11 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I have a 250 in my '64 Chevy II wagon with a Cifford intake, headers and a Holley 390 cfm carb. One tip is to use a factory style, 1 piece intake/exhaust gasket. Use High Temp RTV on both sides of the gasket. This will prevent almost all leaking issues. I ran into that problem with exhaust leaks from the PO. I also had a points dizzy originally and converted over to HEI and it runs so much better.
Here's a pic.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-17-2015, 09:52 PM   #4
Mthumphrey
Mthumphrey's Avatar
Thanks guys!!!
Old 06-17-2015, 09:52 PM   #5
Mthumphrey
Mthumphrey's Avatar
Nice engine Chevy_Mike!
Old 06-18-2015, 05:11 PM   #6
Mackie
Mackie's Avatar
I will add that a fuel pressure regulator is just about a must with Eddy carbs, whether its mech OE pump or electric. They don't like more than 5 lbs.. 4.5 is OK usually unless your doing mostly WOT pulls..
`63 C-10 Shortwide
Roller 305 LT1 cam, Eddy 500
T5
Mackie is offline   Reply With Quote
Old 06-19-2015, 11:00 AM   #7
luvbowties
luvbowties's Avatar
Cool Re: Installing Edelbrock 500
Hey, chevy_mike, that's a very sharp-looking engine setup. Just gotta love it!
Sam
luvbowties is offline   Reply With Quote
Old 06-19-2015, 11:17 AM   #8
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I ran a pump without on regulator on my edelbrock without issues. Though sometimes I may have had issues because the engine would load up sometimes maybe from to much pressure. But for cruising it was fine.
Old 06-19-2015, 11:06 PM   #9
66Submarine
66Submarine's Avatar
Yeah...if it loads up you have an issue.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 06-20-2015, 09:52 AM   #10
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
haha. Until I gave it the gas. It was either float level or too much pressure. Give it gas and off we go with no hesitation.
Old 06-20-2015, 10:07 AM   #11
AcampoDave
AcampoDave's Avatar
I run a 500 Eddy on my 283. They come on the rich side from the factory. (Perormace and dual quad applications). Mine worked bettter after I leaned it out 2 stages in the cruise mode.
AcampoDave is offline   Reply With Quote
