Old 06-16-2015, 10:49 AM   #1
68panelman
68panelman's Avatar
67-71 door panel caption nut
As title says, Does anyone reproduce these little square caption nuts that holds the lower four screws on the metal door panels? I can't find them anywhere.
Mike
68panelman is offline   Reply With Quote
Old 06-16-2015, 11:22 AM   #2
Willie Makeit
Willie Makeit's Avatar
Re: 67-71 door panel caption nut
You should be able to source these locally, do a google search for "1/4-20 cage nuts"
Willie Makeit is offline   Reply With Quote
Old 06-16-2015, 12:18 PM   #3
68panelman
68panelman's Avatar
Ok thanks Willie, I guess the right terminology also helps
Old 06-16-2015, 12:23 PM   #4
Userone
Userone's Avatar
I used license plate screw things from the part store. They fit right in the square. cost like 2 bucks or something
Userone is offline   Reply With Quote
Old 06-16-2015, 12:37 PM   #5
cdowns
cdowns's Avatar
tryace hardeware
Old 06-16-2015, 12:53 PM   #6
68panelman
68panelman's Avatar
Originally Posted by cdowns View Post
tryace hardeware
yeah I tried calling both ace and true value to save my self a trip, of course I deal with kids who have no idea what I'm talking about. I'll try the big box stores
Old 06-16-2015, 12:58 PM   #7
RenoKeene
Florida Edition
RenoKeene's Avatar
^^This, works perfectly.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 06-16-2015, 02:28 PM   #8
cdowns
cdowns's Avatar
calling is a lame way to try and find something// goin down the isles and LOOKING is the oldscholl way to uncover the hidden gems as well as lookin for what thewy have so you have it for future referance
Old 06-16-2015, 02:34 PM   #9
68panelman
68panelman's Avatar
true ^, but it sure beats wasting gas for nothin'
Old 06-16-2015, 02:39 PM   #10
Davidf
I have the same issue and the nylon insert is a great idea. But, I am also missing one for the arm rest and I am not so sure the nylon insert will be strong enough (although they really are fairly strong...those inserts are holding the mirrors to my doors...done by PO). Anyway, I was simply going to weld a nut in the proper position. Just a few tacks from the front side would be sufficient.
Davidf is offline   Reply With Quote
Old 06-16-2015, 02:51 PM   #11
my67c20
McMaster Carr, search for cage nuts, best source i found for odd stuff, and the best part is they deliver and usually the next day.
my67c20 is offline   Reply With Quote
Old 06-16-2015, 02:56 PM   #12
68panelman
68panelman's Avatar
Fastenal and mcmastercar need big orders 500 plus pieces. I'm sure home dumpo will have some in their bins
Old 06-16-2015, 04:07 PM   #13
my67c20
68panelman i have bought from McMaster for a long time with small orders. These cage nuts come 25 to a pack and you can order just one. Sometimes there stuff is more expensive than at ACE, but rarely have i run into a minimum buy situation.
Old 06-16-2015, 06:42 PM   #14
cdowns
cdowns's Avatar
yep save yer gas don't bother learin anything for the future
Old 06-17-2015, 07:22 AM   #15
Calling ahead is the smart thing to do. If they have what you want you go there then you can educate yourself. calling doesn't prevent you from ever walking down the isles, it prevents you from wasting time, fuel, and frustration. I've been there, Ace doesn't sell these
Old 06-17-2015, 08:41 AM   #16
68panelman
68panelman's Avatar
I'm always learning like us all on here, what I don't like is people making assumptions of other members knowledge
I've been playing with these trucks for quite some time, over 25yrs, and this is the first time I don't have this nut in house (believe me I save everything)
You should change your screen name to "Putdowns" cause out of your 22,200 posts, there're all negative.
Old 06-17-2015, 10:45 AM   #17
Willie Makeit
dude, why are you such a goob to people? I mean seriously, if you have nothing to offer except sarcastic & mean-spirited replies then why bother at all?
Old 06-17-2015, 10:48 AM   #18
Willie Makeit
Those will work as well. Found mine at the local Lowe's store and used them on my armrests. They were in the little drawer bins in the hardware section where you can find all sorts of oddball tid bits.
