06-16-2015, 01:37 PM | #1 |
Porterbuilt A-Arms problem.
Hey guys got the steering hooked up the other day and ran into a problem witht the rim rubbing on the swaybar mount when the wheel is turned. These wheels are just temporary but I dont think I have read about this before. The wheels are 19". I'm hoping when I order the new wheels this wont be a problem. Has anyone else had this happen?
06-16-2015, 02:51 PM | #2 |
Re: Porterbuilt A-Arms problem.
Which configuration arms did you get?? I have 1 inch forward lower arms on order.
1970 Shortbed 2wd C-10 |
06-16-2015, 03:52 PM | #3 |
Mine are doing the same thing, 1" forward and 1" narrowed. I have 18x9.5" Z06 replicas with 1.5" spacers for mock up. I'll have to relocate the sway bar mount so I can run 18x11" like I'd planned.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
06-16-2015, 03:53 PM | #4 |
67-72 parts collector,…
Wow.
What width wheel and how much backspacing?
06-16-2015, 04:05 PM | #5 |
Mine are 9.5" wide, +57 offset with a 1.5" spacer. So around +19 offset. That works out to 6" backspacing.
06-16-2015, 07:25 PM | #6 |
With the PB control arms, you can only run so much backspacing on the wheels, due to that sway bar tab.
08-25-2016, 05:14 PM | #7 |
A guy with a truck
I'm running the PB/Addco bar with stock control arms and get the rub. The issue is that the bar is just so wide--great for leverage, bad for tire/wheel clearance.
Talking to Dave at PB, he recommends no more than 5.25 BS with the bar. My 20x8.5s w/ 5.25 just barely rub... What have you guys with wide front tires done to accommodate? I'd like to bump up to a wider front wheel/tire combo. Seems like weld a new tab and use a narrower bar is a potential fix.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-26-2016, 12:55 PM | #8 | |
Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
08-26-2016, 05:11 PM | #9 |
A guy with a truck
That sound is me clapping my hands. In my cube. At my desk. At work. Need a test mule?
08-27-2016, 11:15 PM | #10 | |
1983 Chevy C10 250/3spd (current project truck) 1976 Chevy C10 350/350 Heavy Half (future project truck) |
08-29-2016, 05:04 PM | #11 | |
The sway bar tab has been in the same location for 8 years... LOTS and LOTS of arms out there. This really hasn't been much of a concern. But as mentioned above... feel free to follow up with us if you have any concerns. Nate
09-06-2016, 12:06 AM | #12 | |
Thank you
09-09-2016, 03:35 PM | #13 |
Dam. Now I am a bit concerned since I plan on running 305 tires up front with wheels measuring 6 inch backspacing. I hope I don't run into these issues as well.
