Tire Fitment
I just picked up at 71 K20 with a 3" body lift and completely shot 35's. I'm not a fan of the body lift and plan to return it to stock height. I would like to say with an off road/mud tire, but I'm not sure what size tire I can run without the lift.
What is the biggest size tire I can run on a stock 71 K20? |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Tire Fitment
It depends partly on wheel width & offset. You should be able to run a 32-33" tall tire as long as you don't go wider than a 8" wide wheel. The most likely area for potential clearance problems is the lower front corner of the fender.
Re: Tire Fitment
Thanks!
