06-17-2015, 10:34 AM | #1 |
Air intake tube options
What are you guys using for airtube and filter? Battery is being moved to the back....so I can go left or right. Going into a 66 with an LQ4.
06-17-2015, 10:45 AM | #2 |
Re: Air intake tube options
I used a stock airbox setup. Cheap and easy to find.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e) 1990 K1500 Daily |
06-17-2015, 11:18 AM | #3 |
I Plan on using this. TRKFRK used it.
Amazon.com: GMT800 V8 Truck/SUV 4" Aluminum... http://67-72chevytrucks.com/vboard/s...424609&page=21
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
06-17-2015, 12:31 PM | #4 |
meowMEOWmeowMEOW
A perfect segue for me to insert myself lol
Moving the battery Building an air box for an ls swapped c10 *I have pics in my build of the intake kit I started with. Its the 2004 Silverado cold air intake which you can easily find in 50 version on ebay for under $50...which has had the tubes flipped and brackets trimmed. I did add an additional bend from Spectre, but only because my intake had been modified already once before. But its possible to make a functional intake with just the cheap Silverado kit by itself.
06-17-2015, 01:19 PM | #5 |
Thanks for the videos. What engine cover is that off of? I have the basic Vortec one and don't like it.
06-17-2015, 01:40 PM | #6 |
Post Whore
I used spectre fittings and filter and 4" mandrel bent alum tube...got everything i needed off ebay.
06-17-2015, 03:43 PM | #7 |
meowMEOWmeowMEOW
No problem. The cover is the 3-piece vortec max cover. It came on some of the Denali's, Yukon XL's, and I think a couple of the high-option package trucks. Its the same basic cover as the "vortec 6000" and Cadillac 3 piece covers, but the center just has "Max" on it instead of something else. Lettering was just hand painted on since everyone kept asking what size motor it was.
06-17-2015, 06:55 PM | #8 |
If you are using MAF sensor, make sure you have 4" tubes. I got a unit off Ebay that downsized from 4" to 3.5" at the throttle body and kept getting codes. Changed to 4" and no more problems.
06-17-2015, 07:37 PM | #9 |
meowMEOWmeowMEOW
The throttle body and MAF are 85-92mm depending on exact combo, either of which shouldn't have a problem with a 3.5" tube (87mm is ~3.4")
Are you sure it was the tubing size that caused the issue, not the actual placement of the MAF in relation to the tubing and bends?
06-18-2015, 12:12 AM | #10 |
where should the MAF be placed within the tubes?
06-18-2015, 02:06 AM | #11 | ||
meowMEOWmeowMEOW
You want it in a straight run of tube, with at least a few inches before any bends or any portion which may create turbulence. This includes keeping it far enough away to avoid turbulence from the throttle body. Here's the reference from gm: Ensure the MAF sensor is oriented correctly in the induction (it will only read correctly in the proper direction). An arrow is located on the sensor indicating correct flow direction. Verify this before welding the mounting boss, as the sensor will mount only one way in the boss. Ensure the MAF Sensor is mounted in the middle of a minimum 6 inch length of 4 inch diameter tube, and is a minimum of 10 inches from the throttle body."
06-18-2015, 09:12 PM | #12 |
I used two eBay Silverado kits with a k&n. Mass needs to be in the longest straight section of pipe at least 10" away from the tb for best results.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 06-18-2015 at 09:18 PM. |
06-18-2015, 10:52 PM | #13 |
The advice that you've been given so far is good and is directly in line with the GM recommendations, but I found that MAF placement was quite forgiving in my case. I attached the MAF directly to the throttle body and it runs great and has never thrown any codes.
06-18-2015, 11:20 PM | #14 |
Mine was directly on tb too and seemed to be fine , that is until I dropped a cam in it. Then it started running lean and popping through the intake.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
06-19-2015, 08:53 AM | #15 |
Old member
Mine on the 6.0 in the 71.
Hole cut in support for the cold air. 90 model Caddy box modified for it. Lowes ninty and 2 couplings. Mounted in the truck.
06-19-2015, 08:26 PM | #16 |
thanks
06-21-2015, 03:31 PM | #17 | |
And what are those valve covers and/or heads with the perimeter bolts..??
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
06-21-2015, 04:38 PM | #18 | |
