06-17-2015, 11:19 AM | #1 |
Rear disc brake kit confusion
I did a search and boy am I confused. I have a 68 1/2 ton with a 5 lug rear. Is there any kit out there for rear disc brakes that you don't have to pull the axles? Maybe just cut the backing plate off. Could someone list all the parts I'll need to complete this swap. Thank you, Larry
06-17-2015, 12:19 PM | #2 |
Re: Rear disc brake kit confusion
pulling the axles out is not a big deal...look into it
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
06-17-2015, 01:10 PM | #3 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-17-2015, 05:16 PM | #4 |
pulling the axles is easy but not needed in a lot of cases. It would be a good time to pull and replace the seals also.
06-17-2015, 05:45 PM | #5 |
You likely only need to pull the axles on C-clip rear ends. Which could be the case on a half ton, but the HD ones are all floating axles.
There may be ways to install that kit, as mentioned above, without pulling them. But the Cadillac rotor system thats in a lot of kits does require it. Either way the drum backing plate has to come off, right? Does it get cut off?
06-18-2015, 11:41 AM | #6 | |
06-18-2015, 06:43 PM | #7 |
thanks for all the help guys. think I'm going to go with Scarebird's kit
06-18-2015, 07:00 PM | #8 |
06-25-2015, 12:40 AM | #9 |
just heard back from scarebird. he doesn't offer a rear disc brake kit for our 67-72 trucks.
anybody else have a kit besides cpp & captainfab? |
06-25-2015, 07:14 AM | #10 |
Old member
I don't know how anyone can put the CPP kit on a rear truck axle without removing the axles unless they started fresh with no drums. I had to remove mine and put new seals on it while I had it out. I did the bearing a few years ago and seals. The backing plate has to come off of the rear end to mount the disc brake bracket. It will not slide over the flange.
06-27-2015, 12:17 AM | #11 |
I'm in LA for 2 weeks of vacation. I stopped in CPP today and bought the rear disc brake set up. The 2 counter guys were very helpful and friendly
