06-17-2015, 01:06 PM | #1 |
Second Chance Program
90 suburban rear doors on a 77 crew cab?
Will it work? By the looks of things the doors are physically the same. It's just the guts that are different. Is that correct? So I can gut my 77 doors and put the innards in the 90 doors and be good to go?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
06-17-2015, 04:06 PM | #2 |
6>8 Plugless........
Re: 90 suburban rear doors on a 77 crew cab?
I believe so. You will probably have to drill some holes to mount your door panels on the doors. I've asked others and this is pretty much what we came up with. I have a lot of 81 up rear doors and i thought about using them, but then I got a pair of near perfect rust free 76 doors.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-17-2015, 04:10 PM | #3 |
They are a direct bolt on with no issues. There won't be any extra holes to drill putting them on a 77
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
06-17-2015, 06:52 PM | #4 |
Thanks! What about the window regulators? Lmc lists them as 81+. The 90 doors have power windows and I want to stick with the manual ones in the 77. Will the 77 regulators bolt up to the 90 doors?
06-18-2015, 10:03 PM | #5 |
78K & 79C Jimmys
89 bolted up to my 78 no probs,but somebody did point out the roller wheel size changes at some point
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-19-2015, 12:01 AM | #6 |
77-91 should be the same shell...
Might be a regulator change (minor) in those years but nothing that would keep you from using the doors... |
06-19-2015, 12:25 AM | #7 |
Very good. Thanks everybody!
