new here! needs brake shoes...
names Robban from Sweden.
Need some help. Wifes got a chevy -66 c3605. There is a leak right on the brake shoes from the rear axel. I found a new gasket (seal?), but brake shoes is a bit harder!.. what does 15x4 mean? 15? 4 with on the shoe? or the brakedrum? It seames a bit hard to find shoes for here c30.. Sorry if my english is bad.... please help... ![]() |
Re: new here! needs brake shoes...
Welcome and great looking truck your wife has!!!
Are you looking for the wheel cylinders? That's the part where the rear brake lines would connect to. Or do you need brakes themselves?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-18-2015 at 01:21 PM. |
The cylinders are available at NAPA auto parts.
Left UP9344 right UP9345 Rear brake hose (goes from frame to rear diff) UP33676 Rear brake spring kit UP2250 Have had no luck finding the rear brake shoes, but the fronts seem available.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#6 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Welcome to the forum Robban
![]() The 15 x 4 you ask about would normally be referring to the diameter (15 inches) and the width (4 inches) of the drums and correct shoes. However that does sound a bit large for a Eaton HO52/72. I would have thought those shoes to be closer to 13 inches in diameter and about 3 inches wide. I would say that you will need to measure the shoes that you have and let us know and possibly we can help you find them here in the US and get them shipped to you. Regardless, I do understand your difficulty in finding the brake shoes there in Sweden. The back of the cab at the roof and side on your wife's C30 looks a bit odd. Do you have any pics from the rear or the side?
#8 | |
Mystery solved.......C3605 would be a panel. So I'm guessing it was cut down and modified to a truck. The research I found showed 2 3/4" back brake pads....
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-19-2015 at 09:18 AM. |
Very nice. I see that it was a panel truck originally. Did you purchase it that way or do the mods yourself. I like the split back window.....very cool.
Really nice truck you have bloodwheel. I like the lights and glass in the back. Definitely different.
You have a later 14 bolt rear end that someone swapped in, not the original Eaton rear. Measure the width of the shoes and the inside diameter of the brake drums to determine what shoes you need.
Googling the casting number on the wheel cylinder seems to come up with one for a '74-'75 C20 or C30, which is probably what the rear end is from (and what you need to buy parts for). Going by your pictures, I am going to guess a 13" x 2.5" shoe for a '75 C30 will probably get you back on the road. Hope this helps! |
#13 |
66sub you beat me to it i thought that drum was for a 14 bolt then i read farther down the post and seen yours... 13 x 2.5 is probably correct
#14 |
#15 |
The truck was original a ambulance sold in sweden in 1967.
I think it rolled in Uppsala for many years.. Then it got sold of and around 1980ish some of the previous owners cut i up and made a pickup truck instead. I rolled as a flour truck for a couple more years. I guess some along the way it got a bit worn and to old.... We found 10years ago in a garden without a engine and a broken 700th tranny on the bed.. We bought a Camaro 305 engine och replacet the 700th with a working one Did some welding,abit of paint and tada... Electrical systems is from a 1987 van. Its got PS,PB. She did alot of the work herself Good fun and very easy to drive... Last edited by bloodwheel; 06-20-2015 at 03:45 PM. |
#16 |
#17 |
So the rear axel is not original!!!I didnt know that!
I have never replaced the brakes on the back, just the front... I will take apart the drum next week och mayby take a better picture of the axel! |
#18 |
60-66 Nut
If you can take a picture of the rear cover in the center of the differential, that will help confirm what differential you have.
#19 |
#20 |
#21 |
60-66 Nut
Yes, that is a 10.5" full floating 14 bolt differential.
#22 |
so its from a '74-'75 C20 or C30 or.....?
#23 |
60-66 Nut
The 10.5" full floating 14 bolt was used from '73 up into the 2000's in C/K20's and C/K30's. The easiest way to know the exact year would be to pull the rear cover and find the date stamped on the ring gear. There is a code stamped on the passenger side axle tube, but then you will have to find a listing for the 14 bolts to find the year and gear ratio.
#24 |
#25 |
didnt find anything on the side axle tube....
