06-18-2015, 06:50 AM | #1 |
Paint amount???
I am real close to painting my 71 SWB. I will be painting the entire truck, inside & out, top & bottom. Using base/clear. Question is how much paint to buy? I don't want to reorder because of mixing.
Thanks |
06-18-2015, 09:10 AM | #2 |
Re: Paint amount???
I would do the interior and inside the bed with a single stage, two quarts would do it. then one gallon each of the basecoat and clear coat would be sufficient for the exterior, if you choose to do the interior and inside bed with 2 stage...I would suggest one gallon and a quart for the base and clear.
1953 Chevy 3100 1964 Chevy Impala 1966 Chevy El Camino 1970 Chevy C10 Fleet Long 1972 Chevy C10 Step long 1985 Chevy K10 Fleet Short |
06-18-2015, 09:23 AM | #3 |
Re: Paint amount???
what color r u using
06-18-2015, 09:28 AM | #4 |
Re: Paint amount???
SPI red over white epoxy.
06-18-2015, 09:36 AM | #5 |
Re: Paint amount???
I painted my stepside with single stage, I used one gallon of color + whatever the reducer & hardener was, and I just barely had enough for 2 coats on the entire truck for just the outside (short step side).
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-18-2015, 11:18 PM | #6 |
Re: Paint amount???
I bought 2 gallons for inside and out and sprayed two base coats ( Long bed). Now I have about 2 quarts left for touch-ups. I used about 2 quarts of clear, but I didn't clear inside of bed.
06-18-2015, 11:33 PM | #7 |
Re: Paint amount???
It's not as easy as how much paint to buy. Better paint will take less coats to cover then cheap paint. Dark colors cover faster then light colors. Single stage needs more coats then bc/cc. Different mixing ratios will give different amounts of spray able material. Etc etc. 2-3 gallons is a good starting point.
06-18-2015, 11:34 PM | #8 |
Re: Paint amount???
There is going to be a couple of factors... depending on what color you use and pai t manufacturer it could be a little slower covering but I would definitely get 2 gallons to be safe. If your just going with a basic blue black you will be fine but if it's a custom color I would go to Lowe's and buy a bucket and mix both gallons together just to make sure it's a perfect match because most automotive paint stores will only mix a gallon at a time and if some flunky adds a little more of a single color it could be a bigger deal than you would imagine espically assuming your taking it all apart and going to paint different pieces on different days.
06-19-2015, 11:09 AM | #9 |
Re: Paint amount???
Just did my step side; 2 gals base + reducer; maybe a qt left. 2 gals clear + hardner, none left.
1968 StepSide GM 350 Crate / 700r4 |
06-19-2015, 11:21 PM | #10 |
Re: Paint amount???
Just painted my Jeep J10 with SPI pure white over grey epoxy sealer. The SPI base is a 1:1 mix with their slow reducer. I bought 1 gallon (4 quart cans) which makes 2 sprayable gallons and ended up ordering one extra quart before finishing the bed just because I was cutting it close and didn't want to run out.
Like you I also painted the inside of the cab and firewall/inner fenders. The red should cover the white sealer well, but I would still order 5 quarts. Dump 4 quarts into a clean new paint can and after you have used some add the 5th quart. SPI stuff sprays pretty nice, good choice.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
06-20-2015, 10:36 AM | #11 |
Re: Paint amount???
not wanting to hijack anything, but here is another question....what does paint cost generally speaking? (ie: the paint, the clear coat, etc?)
Per quart or per gallon? Thanks! Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
06-20-2015, 12:43 PM | #12 |
Re: Paint amount???
interested ...
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD 70 CHEVY C/10 LWB x 2 ----- SOLD 67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN " Build thread : http://67-72chevytrucks.com/vboard/s...15#post6826315 |
06-20-2015, 07:30 PM | #13 |
Re: Paint amount???
You can spend a lot of money on custom paint depending on a number of factors. Single stage, base/clear, metallic, manufacturer, etc. Below is a link to SPI's pricing, (who I use) you can order directly from them and they do not charge anything for shipping. Many consider their epoxy they best available for restoration work and they have a great user forum with a lot of knowledgeable members who are very helpful.
http://www.southernpolyurethanes.com/#!pricing/c20uv Jeff
