Old 06-18-2015, 10:46 AM   #1
onetonwrecker
onetonwrecker's Avatar
clutch help
hey guys, I need some help. I've searched just about every forum there is and have come up short. I have even done a lot of reading on 4btswaps page. I'm currently putting a 6bt and getrag 5 speed in my 1968 Chevy c-30. motor mounts are done, trans mounts are almost done, but I'm have trouble finding info on clutch master cylinder set ups. I'm going to run the hydraulic clutch. what's the best way to do it, should I find a wilwood master with the same dimensions as the stock dodge? or use a stock dodge master and somehow fix it to the pedal assembly? advice and pictures would be awesome
onetonwrecker is offline   Reply With Quote
Old 06-18-2015, 01:41 PM   #2
cooperhw
cooperhw's Avatar
Re: clutch help
You might want to look at a clutch slave cylinder from a 2004-04 GTO or Corvette maybe. I used one of these when I put a T56 Tremic in my 67 Chevelle. Just had to get a bracket and remote speed bleeder from Tick Performance. (not 100% sure on bracket) h*ll to get old.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 06-18-2015, 03:43 PM   #3
onetonwrecker
Re: clutch help
ill have to check that out. I need to get some pictures up here
Old 06-18-2015, 04:56 PM   #4
RodnRudy
RodnRudy's Avatar
Re: clutch help
Check out American Powertrain, they specialize in that kind of stuff. They were really helpful on a buddy's 62 Vette
RodnRudy is offline   Reply With Quote
Old 06-18-2015, 05:09 PM   #5
trkfrk
trkfrk's Avatar
Re: clutch help
I installed a hydraulic master cylinder from an off road shop, JAMAR is the brand. They also offer rebuild kits for them. Straight forward install. Hole through the firewall and a 3/8" hole in my clutch pedal. Works great.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 06-18-2015, 05:13 PM   #6
trkfrk
trkfrk's Avatar
Re: clutch help
Pic 2
Mark
