Stripped threads on TH350 transmission
When I took my transfer case away from my transmission I though it was odd that it had three studs and one bolt. There was a bolt in the lower left hand spot if you are looking at it from behind. This is right next to the (sorry for sounding like a complete idiot, but I am with transmissions) round cover in the back... the modulator maybe??
So anyhow, when I went to put it all back together today, that bolt would not tighten up. It almost did, but never really got tight. Tried putting a stud in, but just wound up with what was left of the threads on my stud. My question is... Can I just run a tap in that hole to the next size larger bolt, or will I end up with shavings where I don't want them. I can't tell if that hole is open to anything inside the transmission. I know that it is not open to the area right next to it where it mates to the transfer case adapter. What are my options here besides a complete tear down? |
Re: Stripped threads on TH350 transmission
You might be able to, I honestly don't know. I myself would pull the transfer case and helicoil it. Then you have good solid foundation. JMO
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
