06-18-2015, 06:38 PM | #1 |
Check The Champ, Demonstrator
250, no oil pressure
Started the 250 after sitting for 4+ years and it ran great. Drove it down the street and it began to sputter and then backfired. Pulled it back to the garage and found the distributor was loose. Set the timing position as it always was pointing and the truck started right away. BUT, now there's no oil pressure.
Pulled the distributor and the tongue on the end of the shaft is still intact. Installed another oil pressure gauge, no pressure. Started and idles great. Did something to the oil pump? Dropped the pickup tube?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
06-18-2015, 09:13 PM | #2 |
Re: 250, no oil pressure
Have you tried using a priming tool to spin the pump ?
Between saying and doing many a pair of shoes are worn out |
06-18-2015, 11:19 PM | #3 | |
06-19-2015, 05:45 AM | #4 |
No, I did not try a priming tool as suggested. Time to make one.
Tried two other pressure gauges without success.
06-19-2015, 07:56 AM | #5 |
priming the pump helps ..
also cheque the clearance of the pickup to the oil pan ... it might need to be adjusted
dont want to hear excuses, i want to hear solution(s) |
