06-18-2015, 11:21 PM | #1 |
1970 C10 Firewall outside air door diaphragm
Does anyone have a picture you could post showing how to connect the outside air door diaphragm on the passenger side to the outside air door. I bought a new diaphragm and new air door, but seem to be missing some parts to connect them together.....Thanks.
06-18-2015, 11:41 PM | #2 |
Re: 1970 C10 Firewall outside air door diaphragm
Welcome to the forum!!!
If I understand what you are looking for, maybe the photo below and the LMC catalog link will help. The air door is not visible in the photo. http://lmctruck.com/icatalog/CB/full.aspx?page=162 |
06-19-2015, 01:19 PM | #3 |
Not to hijack this thread, but is there suppose to be a spring as I see in the picture. if so mine appears to be missing
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
06-19-2015, 02:27 PM | #4 |
There is a spring but a lot of them have rusted or fallen off. There should be a plastic bushing drilled in the firewall behind the glove box. then you can install the flap into the plenum then outside the firewall there is an oval white plastic bushing that attaches with 2 screws (See photo in last post) then the metal offset crank is attached with a set screw. This crank attaches to the vacuum pod. Once you remove the cowl vent it is very easy to change this out. I need to replace my 1970 c10 one also.
06-19-2015, 02:35 PM | #5 |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 06-19-2015 at 02:49 PM. |
06-19-2015, 03:13 PM | #6 |
Yes, there is supposed to be a spring. It's fairly stout and, as stated above, usually M.I.A. For that reason, originals are very hard to find. Here's a picture.
Jim |
06-19-2015, 04:07 PM | #7 |
Yes, FirstOwner, that is exactly what i am looking for. Based on your picture, I am missing the 90 deg. elbow that connects the vacuum pod to the door. Anybody know where I could get that piece? Doesn't appear that LMC sells it.
Can anyone tell, or provide a picture, showing what the spring is attached to? Thanks everyone! |
06-19-2015, 04:49 PM | #8 | |
You may find someone selling the elbow on the parts for sale board. Jim |
06-19-2015, 11:15 PM | #9 |
Okay...I see the spring now in the background. Thanks a lot for your help, Jim!
