Old 06-19-2015, 08:26 AM   #1
rusty66c20
My 1966 C20
First post. First Chevy truck. Have a 1966 C20 that the ppo had started to restore. I have a few questions.
#1 The rear brakes sheen stuck. Drivers side won't roll at all. Passenger side will only roll backwards. How big of a pita will it be to get it freed up?
#2 Not sure what engine I have. 327 or 350? Can I tell by just looking? Also need a radiator.
#3 Does anyone reproduce the C20 fender emblems?
#4 My steering column has a pointer sticking up behind the wheel. Automatic column?
rusty66c20 is offline   Reply With Quote
Old 06-19-2015, 08:31 AM   #2
corvettejim1968
corvettejim1968's Avatar
Re: My 1966 C20
original engine would be 327
I know they make c10 and maybe c20. brothers trucks,classic parts,LMC are some vendors. So-Cal has radiators
yes auto column
welcome to the forum
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 06-19-2015, 09:21 AM   #3
1963c-10
1963c-10's Avatar
Re: My 1966 C20
Easiest thing to do is pull the drums and do a good inspection. Replace what needs replaced.
Only way you'll know what you have for an engine is to run the suffix code.
No one repops any emblems but the light duty trucks (apache 10 or c10 series)
And yep....pointer on top of the column would be an auto column
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-19-2015, 09:31 AM   #4
DPowers
DPowers's Avatar
Re: My 1966 C20
Welcome to the forum. Keep an eye on the parts board for the emblems or swap meet.
DPowers is offline   Reply With Quote
Old 06-19-2015, 11:11 AM   #5
OldGMJon
OldGMJon's Avatar
Wink Re: My 1966 C20
[QUOTE=rusty66c20;7214684]First post. First Chevy truck. Have a 1966 C20 that the ppo had started to restore. I have a few questions.
Just get under the truck and back off the brake shoes to free up the wheels...
Projects:
65' Chevy C10 swb (rebuilt chassis)
65' Chevy Panel swb
64' Chevy C30 flatbed "above" 80' C30 "beneath")
Parts:
66' GMC 2503 & 65' GMC I1500
OldGMJon is offline   Reply With Quote
Old 06-20-2015, 01:36 AM   #6
Captainfab
60-66 Nut
Re: My 1966 C20
As for the brakes, have you checked to be sure that the e-brake and or cables aren't stuck?
Old 06-20-2015, 11:29 AM   #7
1976gmc20
Re: My 1966 C20
That might work. My 1965 would "over-adjust" on one side and then get stuck, and I would have to crawl under and back it off.
I finally just turned the doo-hickeys at the bottom end for end so it became manual adjust only
Also could be the one drum is froze to the shoes In that case you will have to jack it up, take off the wheel, and heat the outside of the drum with a torch until it pops. I once made a trailer out of an old truck frame and when I got all ready to pull it, one side was froze up like that
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 06-21-2015, 01:41 PM   #8
rusty66c20
Re: My 1966 C20
Im going to try to post some pictures.
Old 06-28-2015, 02:49 PM   #9
rusty66c20
Re: My 1966 C20
A few more questions. What is the height difference between the low and high transmission hump?
How can I tell what manual transmission is in my truck?
Ditch the split wheels?
Old 06-28-2015, 03:41 PM   #10
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: My 1966 C20
Ditch the split rims. She could use some tender love and care fer sure. I'm pretty sure you have the original sm420 tranny.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-28-2015, 03:57 PM   #11
1976gmc20
Re: My 1966 C20
Heck, at least keep the split rims for spares!
I wish that I still had a set. I can fix flats on those myself at home.
Old 06-28-2015, 07:56 PM   #12
rudyyloverboiii
Re: My 1966 C20
If the reverse is all the way to the left n it's a 4 speed I believe it's an sm420. All the way to the right sm456. Muncie 4speeds
rudyyloverboiii is offline   Reply With Quote
Old 06-28-2015, 07:57 PM   #13
jtrichard
Re: My 1966 C20
THE high hump is the same height as the hump under the center of the seat, covers all the trans except about inch or 2 of the shift tower
jtrichard is offline   Reply With Quote
Old 06-28-2015, 11:38 PM   #14
Captainfab
60-66 Nut
Re: My 1966 C20
Your truck has the low hump. Trucks that originally came with an auto trans had the low hump.
Old 06-29-2015, 10:37 PM   #15
rusty66c20
Re: My 1966 C20
That explains the hack job on the transmission hump.
Old 06-30-2015, 12:04 AM   #16
1976gmc20
Re: My 1966 C20
Your wheelbase looks too short for a C-20.
I think what you have is a frankentruck
Old 06-30-2015, 07:59 AM   #17
urmyboyblue
Re: My 1966 C20
Did C20's have trailing arms or leaf springs? I thought only C10's used trailing arms.
urmyboyblue is offline   Reply With Quote
Old 06-30-2015, 08:44 AM   #18
sanford66
sanford66's Avatar
Re: My 1966 C20
The engine might be a 350. Newer carb, intake, water pump, clutch fan, etc. You need to look up the casting number to tell for sure, it's on the back of the block behind the driver side cylinder head. Also the frame looks a little short behind the rear wheels, might just be the way the pic was taken though. Joseph
1970 Chevelle Nomad station wagon
1966 C-10 lwb,250-six,granny 4speed
1966 C-10 lwb,factory A/C,Custom Cab
1954 Delray 2-door sedan [rat rod project]
sanford66 is offline   Reply With Quote
Old 06-30-2015, 10:33 AM   #19
rusty66c20
Re: My 1966 C20
At some point the frame was cut off behind the rear wheels. I can tell...cuts not square.
I also believe the trailing arm cross member on a short bed frame is also under the cab. Also never seen a short bed frame with 8 lug axles.
Old 06-30-2015, 11:40 AM   #20
Lokin4AReason
Lokin4AReason's Avatar
Re: My 1966 C20
boy, if these truck(s) can talk, I bet that they would have some interesting stories to tell ...
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
