06-19-2015, 08:56 AM | #1 |
TH350 external seals/gaskets
Good morning. Looking for a little help from the transmission gurus out there. I am cleaning up my TH350 to go back into my project. It was working well a year ago so I think the internal components are fine. Obviously there is a problem with some. Oil leakage (spent yesterday scraping crud, decreasing today). Hard to pinpoint the exact location. My question is which seal/gaskets should I change to cover all my bases? Was thinking input and output shafts, shift selector, oil pan. Anything else you would replace?
Thanks for the advice! |
06-19-2015, 10:11 AM | #2 |
Re: TH350 external seals/gaskets
I would replace the speedometer driven gear "bullet". They wear over time and leak.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-19-2015, 10:13 AM | #3 |
Kick down cable and dipstick seals
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
06-19-2015, 10:17 AM | #4 |
If it were me in that position, I would replace pan gasket, tail shaft housing gasket, tail shaft slip yoke seal, modulator o-ring, dipstick o-ring, and speedometer o-ring. I think you can do all of these without much disassembly. New filter too. Probably get a good gasket kit and use the pieces needed.
06-19-2015, 03:02 PM | #5 |
looks like most of that came from the engine
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
