Lets see your finned valve covers, oil pans and accessories
I love the look of the finned covers. And have seen quite a few 60-66's that use finned covers. Have been working on my vintage Edelbrocks for awhile. Got stalled working on other things but putting the time in to complete them now.
Started with 4+ coats of various paints & primers. A lot of stripping, sanding and polishing. Have over 35 hours on the pass side cover alone, doing all the work by hand. Passenger side is done and will finish the driver side this weekend which so far I'm up to around 20 hours. A lot of imperfections in these old sand cast covers, but they are starting to look good. Some of the deeper scratches will remain. At the end of the day they are vintage and they have earned the scars they carry. But looking forward to seeing what other finned covers you guys are running and the directions you went with paint / finish. Couple of pics of before and after on my project.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-19-2015 at 11:26 AM. |
Re: Lets see your finned valve covers, oil pans and accessories
These are the finned covers currently on the big block that I'll be removing once I finish the Edelbrocks.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Post Whore
![]() Join Date: Mar 2013
We 6 banger boys can join the club to.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Thanks for the addition TJ. I really like the nostalgic look of the finned items.
I had looked at a vintage offy valve cover for my 230 before I decided which direction to go. There are a lot of finned accessories....side covers and oil filter covers being the most popular after the valve covers. Your engine looks great!!! Looked like the one in this pic
Senior Enthusiast
Here's my early Corvette covers with no visible smog connections. The metal is in such poor condition they virtually cannot be polished, they were instead painted overall Krylon Dull Aluminum same as the intake manifold.
Not as eye catching as polished with paint in between the fins, but they are easy to keep clean! ![]()
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Have always loved those early Vette SB covers. Timeless in my opinion.
I used a pair of old GM valve covers and sourced matching (ish) aftermarket air cleaner and breathers, I've agonised over painting inside the fins but not done it yet.
Getting old sucks.............but it sure beats the alternative |
That engine looks great and I think the air cleaner is a perfect match to the valve covers.
Painting the fins is not that bad. What I do is all the sanding & buffing work 1st. This is where new covers would be nice and very much a time saver. But I wanted vintage so that required much more work. I just wasn't satisfied with the newer options when I was looking for finned covers. I like to use a good degreaser and 600 grit in the valleys to give the paint something to adhere to. Then I tape off the larger surfaces of the valve cover using the 1st fin as my tape line. I use engine paint personally with good results. I have heard of people using cherry chapstick also on the fins instead of taping each fin. The point of the cherry chapstick is you can see where its applied. Paint and then it'll wipe off. 90% of the people I've talked to that have done them say taping each fin is a PITA and would not do it again. But its a personal preference. This is just whats worked for me. Once I've applied several coats and given them some time to dry I go back in with a clean soft cotton rag (normally an old shirt) and acetone. Carefully wiping off the paint from the top of the fins. Take your time as the Acetone will soften any other paint you do not want to remove. Toothpicks are another great tool here. And q-tips will help in hard to get places...I just dip them in the Acetone. Then I do my secondary colors (if applicable). I have done several sets this way and always get great results. I have seen guys use pin stripping tape also to mask each individual fin, but its more cost effective and time consuming in my opinion. Couple of pics of my painting in progress
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-19-2015 at 03:13 PM. |
Your covers look fantastic and thanks for the advice, I must confess I was going to go the masking tape route
#10 | |
So.....maybe we'll see some color in those fins soon then? Keep us updated on the progress!!!! The set I did in post 2 a few years back......the fins stop at the crest of the valve covers like yours. What I did was run tape across the bottom of the fins creating a nice flat line.
Never Ending Projects
A few of mine on some different vehicles
![]() ![]() I have the Mercrusier lifter covers to match, that I haven't installed yet. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Nice. I like the crinkle black on the old Mercruiser valve cover. Saw one on ebay the other day looking at some stuff for a buddy.
My old edelbrock covers I'm working on would have been crinkle black also. Probably due to the imperfections in the castings. There are pits and scratches from the sand castings. I've worked out the minor flaws, but the larger ones will remain. It just is what it is. Thanks for sharing the pics!!!
#13 |
mine
#14 |
Cool thread and well timed. I was just looking at finned accessories.
84 GMC One ton 4x4 454 4 speed 62 Chevy C10 short fleet plus about 13 previous gm trucks from 1960 to 2000 |
#15 |
![]() Join Date: Oct 2006
ok I'll play......
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#16 |
I like that they are equally as liked on the 6cyl engines as well. Its also nice to see such different varieties and painting options.
#17 |
400 small block. Daytona blue.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#18 |
I have valve covers and oil pan. Will be getting a round air cleaner as well. I painted mine similar to how 63C10 except I wiped the fins off immediately after painting with a cotton cloth and lacquer thinner.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Also have a set on my 383 in the Caprice. These were very easy to paint. ![]()
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#19 | |
Post Whore
#20 |
Wrinkle finished with fins. I didn't like the look of the finned air cleaner lids.
#21 |
![]() Join Date: Nov 2013
Hey 1963c-10, I'm digging the chevrolet oil cap filler/plug in your covers. Where did you find it?
#22 | |
I had the hardest time finding a fill cap/ breather. Tried several different ones (5-6) and couldn't find any that would twist in and clear the fins. Then out of the blue I decided to try the original AC Delco FB7 that came off my old 230. Was a perfect fit. The breather was shot though, so I found a NOS replacement. This is the breather I'll be running on the pass side. Will get an aluminum plug for the 2nd hole (haven't decided on the polished or the "oil" plug yet)and then PCV valve on the driver side valve cover.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-22-2015 at 09:36 AM. |
#23 |
BJ I love that color on your small block that is really clean looking
#24 |
Looks really close to the original alpine green.
#25 |
I've been debating on whether or not to add color between the fins (I'm leaning towards painting them red). Thanks for all the tips on which paint to use and how to do this.
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
