Old 06-20-2015, 12:45 PM   #1
Metalaroundstone
Plastic gas filler neck?
My 66 truck has a black plastic filler neck rather than a metal one. I am betting this is unusual and probably an aftermarket part, although I have yet to see this option. Does anybody else have a plastic filler neck or know anything about this? This part appears to be old and seems to function just fine. Is it possible that this is designed to cut down on the possibility of a static charge jumping to the neck during a fillup?
Metalaroundstone is offline   Reply With Quote
Old 06-20-2015, 04:08 PM   #2
jmabx
Re: Plastic gas filler neck?
I'm also curious to know if that is aftermarket. My 65 has a plastic neck too.
Jeremy
jmabx is offline   Reply With Quote
Old 06-20-2015, 04:14 PM   #3
lovemmth
lovemmth's Avatar
I just removed the tank from my 65. I also had a plastic filler neck. I am sure it was original I was able to talk to the original owner (my dad) he had never pulled the tank.
lovemmth is offline   Reply With Quote
Old 06-20-2015, 04:53 PM   #4
plainred65
plainred65's Avatar
My 65 has a plastic filler neck, it's from the Baltimore plant.
plainred65 is offline   Reply With Quote
Old 06-20-2015, 05:52 PM   #5
Jurassic-1
Jurassic-1's Avatar
My 66 has one. I do not know why unless they figured it was safer to fuel up with a plastic neck. no static electricity. I do not know but I am trying to think like an engineer.
Jurassic-1 is offline   Reply With Quote
Old 06-20-2015, 06:32 PM   #6
Uptown83
My 66 had a plastic one too
Uptown83 is offline   Reply With Quote
Old 06-24-2015, 04:08 PM   #7
Metalaroundstone
It sounds like these plastic filler necks were factory. That makes me feel better about this. And maybe they are even safer.
Old 06-24-2015, 05:04 PM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
Both of my 65's had metal filler necks.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-24-2015, 06:19 PM   #9
Metalaroundstone
My truck was made in the St Louis plant. I haven't taken its plastic filler neck off and inspected it for any GM numbers. I assume this plastic neck came from the factory because it seems old and the grommet seemed ancient and the truck did not seem to be damaged in any way on that side. It is a mystery because it seems that most of these trucks have a metal filler neck.
Old 06-24-2015, 06:37 PM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
all my 64-66's (8 different trucks, and the 3 that I parted out as) have the plastic neck, the 60-63's (10 different ones) have steel.
Old 06-24-2015, 06:45 PM   #11
Metalaroundstone
I would say that this information is strong evidence that pastic necks were used in building 64-66 trucks, at least in some GM factories.
Old 06-24-2015, 06:58 PM   #12
joe dirt
joe dirt's Avatar
my 61 has steel neck factory
joe dirt is offline   Reply With Quote
Old 06-24-2015, 07:57 PM   #13
60-66
60-66's Avatar
1963 was the last year for the metal filler neck. that's why the accessory Bowtie Locking gas cap does not fit 64-66 because the ear size is different , although you can install the metal neck in later year trucks , your plastic one is factory 64-66.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
