Old 06-20-2015, 03:03 PM   #1
ratfreak8871
need help. no crank
hello guys. need help with my 79 c10. changed transmission and ignition lock cylinder while trans was in shop. now i have no voltage to the small wire to the starter while in start position. key turns to crank position just fine so i dont think it is anything to do with the new key cylinder. did my ignition switch just decide to go out?
ratfreak8871 is offline   Reply With Quote
Old 06-20-2015, 04:56 PM   #2
greg64
greg64's Avatar
Re: need help. no crank
The start circuit begins at the ignition switch (above the column under the dash), the it goes through the neutral safety switch (location depends on transmission) then it goes out to the starter. I think the wire is usually purple.
So you could probe at the neutral switch to see if it is interrupting the juice there. It'll also tell you if the ignition switch is still working or not.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 06-20-2015, 06:31 PM   #3
Titomars
Titomars's Avatar
Since you just replaced a trans I'll bet your linkage is not adjusted right so the neutral safety is not lined up correctly.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
