Old 06-20-2015, 05:01 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Removing Light Switch
I am trying to remove my dash and and have found the spring button on top of the light switch. I have pushed and pushed and now my fingers are indented and it won't release the light switch when I try to pull it out. Anyone run into this problem or have a suggestion on getting it out. I taped a washer to my finger to put more down force on the spring but that didn't work either.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-20-2015, 05:04 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Removing Light Switch
Greg did you try pulling the knob out as it will go first and then depressing the button on top?
Old 06-20-2015, 05:10 PM   #3
Already Gone
You are the man Pete !!! That was the trick, pull the switch out first, then push on the spring and bingo its out.
Old 06-20-2015, 05:38 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice! Glad you made it home safe btw...
