Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 06-20-2015, 10:08 PM   #1
ogsRULE
ogsRULE's Avatar
Window / Door Assembly
Hi all, I'm getting to the short strokes on my project. Now assembling the doors and windows. I bought this 64 truck completely disassembled so I didn't get a chance to see how it came apart. Can somebody save me from my typical "do it three times" approach and help me with the assembly steps for the door and window? Your expert advice is appreciated I think it goes like this:
1. Assemble wing window with vertical felt (cut to length?) and set aside.
2. Install door limiter (lube)
3. Install window lift assembly (lube)
4. Install door handle, latch assembly and inside door opener assemble (lube)
5. Install felts on sides of bottom of window opening
6. Install felt/gasket along top and rear of window opening (Cut at bottom of window opening channel?)
7. Install lifting glass
8. With glass down, install wing window assembly.
9. It does not appear that any adhesive is used in the assembly.
Thanks much!
Scottie
ogsRULE is offline   Reply With Quote
Old 07-01-2015, 04:36 PM   #2
1963c-10
1963c-10's Avatar
Re: Window / Door Assembly
List looks pretty good, but I always do the 2 window fuzzies last (#5) on your list. Also...on step 6...there is a small tab on the bracket that bolts to the door that will except the end of the weatherstrip. It keeps it from just rattleing around inside the door.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-01-2015, 04:43 PM   #3
1963c-10
1963c-10's Avatar
I know the 64 door is different in design, but the parts and install process is pretty much the same.
Old 07-01-2015, 04:44 PM   #4
1963c-10
1963c-10's Avatar
Last two pages
