Motor Mount Help!
Ok,
1966 C10 had a 283 installing a 350, 4 speed using the original bell housing and crossmember. Here are the mounts I removed from the truck that look pretty beat up and have missing material where the motor mounts bolt runs thru so I figured I would replace them. ![]() Here are the mounts I received but I believe the right side will not work for my application. Looks like one for an I6 application. ![]() Should I try to repair my originals or look for another mount to replace the 'shorter' one?? Advice....
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
Re: Motor Mount Help!
The I6 mounts will work. I just pulled out the 230 and slapped a 350 with a 4speed in my 65. Used original I6 mounts in the factory location and bell housing mounts. I got a lot of guidance from some good folks here and It went in just fine.
Although, those do look like two different mounts, mine were identical I believe |
You have one for a 67-72 i bleave please ignore the picture at first I thought it was a 292 mount.
Between saying and doing many a pair of shoes are worn out ![]() |
That's what I suspected. Figures!!
Guess I'm off to look for a passenger side sbc mount! ![]()
Why not just use the original mounts you removed?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
They are cut up a little and here is material missing in the pad area. I was thinking of welding it up and adding metal there.
Are these side specific?
If I remember correct, in pic 1. The left one is driver side and the right one is pass side. I believe the " notch" sticks towards the radiator.
I can double check tonight if need be.
Yep....notches forward. Went through some old pics from the fleetside.
Thank you sir!
No problem at all.
#11 | |
ron |
