Panel-specific questions
Finally starting to get at my 64 and was wondering a couple of things.
1) the back bumper has a slight bend in it. Is this a panel/burb specific piece? or is it the same as a fleetisde? 2) Will a fleetside rear 1/4 patch panel work? I need the back bottom half behind the rear wheelwell. 3) are there any aftermarket suppliers of rear door seals? and rear window seals? |
Re: Panel-specific questions
Hi mr57. The back bumper is the same as a front bumper but with different mounting holes. You can probably find the indentations where the holes would be for a front bumper. The fleetside patch should work with some tweaking. For the rear seals, most suppliers should carry them. If you can't find them closer try http://billstruckshop.com here in Ontario
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
http://www.steelerubber.com/door-wea...rip-70-1254-72
http://www.steelerubber.com/rear-win...ket-60-0484-81 these are the rear door and window seals.
1960 c30 Apache Panel w/ '95 cummins bt6 turbo diesel (work in progress) NOTE: due to photobucket trying to extort money my photos are temporarily unavailable. currently looking for alternative to fix issue. http://67-72chevytrucks.com/vboard/s...d.php?t=523009 |
I also got my door seals from Steele
