09-05-2003, 10:27 AM | #1 |
71 DELUX
cleaning tips (any?)
OK, fire away.
As I am tearing things down, removing them, cleaning them and returning them, what are some ideas out there for removing 30+ years of road grime and crud? When I can, I use and old screwdriver or a wire brush to scrape away, then some sort of cleaning solvent afterwards. This gets a bit pricey, buying the cans of solvent every week. Any detergents, fabricated tools, etc... that may improve this lengthy process? |
09-05-2003, 10:39 AM | #2 |
Who's in CHARGE??????????
I like soaking my greasey stuff in kerosene for a while & then use a wire brush & paint brush to finish the cleaning, then use either paint thinner or good old soap & water to remove the residue. On big stuff use the kerosene too, it will take a bit longer cause you have to do everything by hand but it'll come clean........joe
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE |
09-05-2003, 11:34 AM | #3 |
71 DELUX
Soap and water, like a granual laundry detergent or dish soap? I'd think that car wash soaps would be too mild, no?
09-05-2003, 12:38 PM | #4 |
Use generic cheap oven cleaner (NOT Easy Off - buy the store brand) ... buy it at your local K-Mart/Dollar Store/Wal-Mart for around 99 cents a can ... spray it on really greasy-grimey stuff ... let it sit ... scrub with wire brush or scrape with a small puty blade.
Be Careful! This stuff contains some sort of acid/solvent/something, and it will burn you if it comes in contact with your skin. Wear gloves, long sleeves and eye protection. Hope this helps! Last edited by Shane; 09-05-2003 at 12:40 PM. |
09-05-2003, 02:50 PM | #5 |
dish soap.car wash works great too, but for those hard to get to & hard to get off stuff, you'll still have to scrub it.........joe
09-05-2003, 04:45 PM | #6 |
carstrol super clean......works great, i'll use nothing else
1981 GMC Sierra 1/2 Ton SWB 4X4 |
09-05-2003, 06:41 PM | #7 |
i vote for the cheap oven cleaner, i spray it on let it sit 1'2hour then spray over it again letting sit for 15minutes then hose it down or pressure washer it into submission
09-07-2003, 10:32 PM | #8 |
I spray the part with some simple green, let it soak, then scrape off the goo with a stiff 1" putty knife. From there it's into the blast cabinet. Everything comes out clean and ready for paint. Just wipe it down with a little grease and wax remover, then prime and paint.
LJ
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
09-07-2003, 11:09 PM | #9 | |
aka Crusher, Crushergmc
ljbear,
FYI: Allowing grease to contaminate your blasting cabinet can very easily contaminate parts you wish to paint later. The high pressure can impregnate the grease into the metal. I wouldn't recommend doing that. I realize you said Quote:
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
09-07-2003, 11:26 PM | #10 |
Jimmy, most of the grease and dirt is off before the blast process. What is there does mix with the abrasive, that's why I said to wipe with the grease and wax remover. Also, the abrasive needs to be changed. In my case I have three different abrasives I use, and always use the cleanest as my final blast media.
LJ
