![]() Join Date: Feb 2015
Aligning the lower control arms after replacement.
Hey guys one more piece of the 63 puzzle, I've replaced the control arm shafts on the one side. Wondering how you place the lower control arms before tightening the u bolts...I upgraded to the bigger dorman ones. Should I measure where the other side is and maker the same?
Re: Aligning the lower control arms after replacement.
Dorman
I dont know about the 63.. but on my 66 I used a 87 lower with shaft's and each shaft has a "alignment" hole in it,, that hole fits to the C-Clamp bolt thats on the cross member..I tightened it up from there
Thank you should that hole be to the front or rear?
As I recall there's a locating pin in the saddle part of the clamp.
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
Rich did a great write up on the stock front end rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=599579
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Yes thank guys its in the front...since I'm pulling it apart again I ordered some new springs...what the heck!
I put the hole in the control arm shaft "Up"... the two C-Clamp brackets that are riveted into the cross member set the shaft,, one of the rivets is larger than the other.. If you align the shaft into the larger rivet side the shaft is aligned at the correct spacing.. If its fit right there's No gap/space between the shaft and the upper bracket.
If I remember correct the Pin is on the forward side,, my shafts had two holes so it didnt matter were the Pin was,, as long as you have the Arms on the right side,, LOL |
Thank you Turtleman!!
![]() Join Date: Feb 2014
Great write up on setting the alignment on the lower control arms. This post is just in time for me, as I will be getting to my front end in the next week.
Thanks, Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
