06-22-2015, 04:25 PM | #1 |
New crossmember in my 48. Is it strong enough?
Hello gentlemen, I'm building a 48 Chevy 3100. I just had a new center crossmember made, wondering if I need to add any more support. I boxed the frame in over the front rear shackle mounts. So they have plenty of support and strength. What I am wondering is, should I add some diagonal braces from where I boxed the frame in over the front rear shackle mounts to the new center crossmember? The reason I am wondering this is the original had that gusset brace in it. Thank you in advance for any of your comments or suggestions.
Rick |
06-22-2015, 04:30 PM | #2 |
Re: New crossmember in my 48. Is it strong enough?
Another picture
06-22-2015, 04:31 PM | #3 |
One last picture
06-22-2015, 05:30 PM | #4 |
Why? are you adding a twin turbo duramax? Your fine.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
06-22-2015, 05:40 PM | #5 |
Assuming you trial fit the drive line to make sure you have enough room to get it in and out from underneath, and the other holes are for exhaust it looks good.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
06-22-2015, 06:08 PM | #6 |
Yes, the driveline is installed and it fits beautifully. And those holes are for the exhaust system. No Duramax, wouldn't mind a Cummings. It's got that 350 in it which is putting out about 350 horse.
06-22-2015, 06:44 PM | #7 |
The only thing I might think about adding is a pair of tubes running back to the frame from close to the center in somewhat of a K to brace it a bit to keep things square.
