Old 06-22-2015, 04:59 PM   #1
MattPSU
MattPSU's Avatar
Radiator Question
I'm about to ad AC to my 1972 C10 that I've swapped a 2005 5.3l into. I'm running the stock C10, 2 row radiator and utilizing the mechanical fan on the 5.3l. Engine and transmission are both stock.
With adding AC, should I consider upgrading to a 4 row radiator or will the stock 2 row handle everything OK?
Thanks - Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 06-22-2015, 10:30 PM   #2
clinebarger
Re: Radiator Question
Is your existing Fan & Shroud moving enough CFM to support a Condenser? (especially at Idle)
Condenser efficiency plays a BIG role.
Your 2-row Copper/Brass should work OK...Pretending it IS in good shape.
clinebarger is offline   Reply With Quote
Old 06-23-2015, 09:38 AM   #3
MattPSU
MattPSU's Avatar
Thanks for the input. Is there a good way to know if I'm moving enough air?
I'm looking at the Vintage Air system, so I would think their condenser would be efficient.
My radiator is in pretty good shape. It wasn't very old when i bought the truck, and it has no damage and it hasn't had any repairs.
Old 06-23-2015, 12:12 PM   #4
ls1nova71
ls1nova71's Avatar
I just checked your build thread, and it looks like you have the fan in the shroud right, so you are going to be moving enough air. I've set all my trucks up that way and they never had cooling problems. That said, they all had at least a 3 row radiator. In fact that's the smallest radiator that came stock in a V-8 automatic truck with air, but LS engines seem easier to cool, so you might be alright with the 2 row. Personally, I would just try it, it won't cost you anything, and if it doesn't work, then look into a bigger radiator.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-24-2015, 07:22 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Radiator Question
Matt you can buy a brand new one for less than $200.00 from O Reilly's, the only thing it want have the inlet on the right side for a cleaner look.
http://www.oreillyauto.com/site/c/de...yword=radiator
When mine goes I plan to buy this one.
http://www.rndfabrication.com/C10middle.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
