Rear window replacement rollers ?
Will the Dorman (#74430) rollers work? or the ones from LMC a better choice? Are there any other options out there?
I know the pieces fit
Re: Rear window replacement rollers ?
I haven't tried either, but without talking to someone who knew better I'd lean toward dorman.
Thanks for your response , I ordered a set(Dorman) to try, I guess no one else has repaired their back window?
I had to change the whole Register because the rollers wore groves in the bottom track and the window would hang up. Maybe I can get the track welded up and replace the flat rollers for the next time.
Well the Dorman rollers were too large. So I went to the dealership and got GM part #'s . Did an online search and found them fairly inexpensive, shipping was more than the parts. If anyone is interested here's the part #'s. Rollers # 4158245 , Rivet # 12338147 .
Thanks for the GM P/N I would much rather have the real thing.
I used a hex bolt and stop nut. It worked great. Pics linked below.
I added the black plastic washers to eliminate rattling. https://www.icloud.com/sharedalbum/#B0L5Uzl7VCgu1l Posted via Mobile Device |
