Active Member
![]() Join Date: Oct 2002
WTB Fuel line
Any one have an original fuel line for small block with Rochester Quadrajet?
I need the one that runs from the fuel pump to the carb. |
![]() Join Date: Aug 2008
Re: WTB Fuel line
I have never found a good original one. They all either had rounded off nuts or had been cut for inline filters.
I bought one from inline tube for around $30 |
One of the First
![]() Join Date: Jan 2000
Re: WTB Fuel line
They are little different on the bottoms, ie 2wd / 4wd - A/C or NON-AC. What do you have? Got a picture?
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
Active Member
Re: WTB Fuel line
My truck is a 1968, C/10, 327, Turbo 400, Power Steering, Non A/C.
The Carb line on my truck has been cut like most to fit an in line filter. I have seen pics here on the board of uncut Carb lines, and the one that I think is correct for my truck... Comes up from the pump runs just above the intake pass the carb toward the rear of engine, then makes a uturn and comes back to the Carb |
Active Member
Re: WTB Fuel line
ttt
#6 | |
Cluster King
![]() Join Date: Nov 2012
Re: WTB Fuel line
The line you need will depend on AC and no AC. The reason for this is the fuel pump will have a can on it with air and no can, without air. On the carb side the line runs back along the intake and does a 90 degree bend and goes directly into the carb. I will check on some and get back with you. It is hard to find the originals that have not been cut or kinked but they are out there. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
