Old 06-23-2015, 06:21 PM   #1
joesscamaro
Cab dolly dimensions?
I'm getting ready to pull the cab off the frame and am wanting to make a dolly to mount it to and to roll it around on. I know some people have made them before, but was wondering if anyone has the dimensions of the cab mounts, so I can actually bolt the cab to my dolly? Open to any pointers on the construction of the dolly also. Thanks!
joesscamaro is offline   Reply With Quote
Old 06-23-2015, 07:14 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Cab dolly dimensions?
What Year?
Old 06-23-2015, 07:18 PM   #3
joesscamaro
Sorry, it's a '66
Old 06-23-2015, 07:46 PM   #4
oldtrux
oldtrux's Avatar
made mine out of 2''x10's
42'' wide-471/2'' long(front to back)
3'' taller at back of cab
sorry pick not that great
hope it helps a bit....dan
oldtrux is offline   Reply With Quote
Old 06-24-2015, 11:36 AM   #5
Wizit247
Wizit247's Avatar
Originally Posted by oldtrux View Post
Attachment 1418482
Good info.
Ill be building one soon. Thanks!
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901
Wizit247 is offline   Reply With Quote
Old 06-24-2015, 11:51 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Sorry I don't have any measurements but this is what I built for my '68 cab. It allows me to roll it around and to rotate it onto it's back, so I could strip the underside.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-24-2015, 08:27 PM   #7
joesscamaro
Thanks for the ideas! I never thought about making it so you can roll it over on the backside...that's good thinking!
Old 06-25-2015, 10:50 AM   #8
chevy_mike
chevy_mike's Avatar
Sure made it easy to strip the bottom of the cab, prime and put Raptor liner on it.
Old 06-26-2015, 12:14 AM   #9
Captainfab
60-66 Nut
There is a nice one in this build thread.
http://www.67-72chevytrucks.com/vboa...Tip+flip+dolly
Old 01-26-2018, 11:36 AM   #10
Artofdeath
Artofdeath's Avatar
Mike,
What size pipe did you use to make that rig? I am going to try to make myself one of these. Did you have to support the back of the cab when you leaned it back?
Thank you!
Artofdeath is offline   Reply With Quote
Old 01-26-2018, 01:54 PM   #11
chevy_mike
chevy_mike's Avatar
Originally Posted by Artofdeath View Post
Mike,
Thank you!
I used 1.5" .090 wall tubing I had laying around. I have a tubing bender for that OD so it was easy.
Nope, no support for the back. It was firmly bolted to the dolly via the factory body mounting points. I could roll it on it's back without any issues. It worked great.
Old 01-26-2018, 02:50 PM   #12
GMC-YA68
GMC-YA68's Avatar
I took a pallet, stacked (3) 4x4 boards on top of it, then screwed 2 harbor freight furniture dollies to the bottom side of it.
I am loving Chevy Mikes set up
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 01-26-2018, 09:07 PM   #13
raidmagic
raidmagic's Avatar
This is freaking genius. Nice work.
raidmagic is offline   Reply With Quote
