Old 06-23-2015, 10:18 PM   #1
sodly
sodly's Avatar
Metal-framed side windows... what years?
Recently I saw a '66 3/4 ton truck with side windows that have the black metal frames along their top edges. I was thinking they stopped using that style of side glass when they abandoned the knee-knocker cab in 64. Does anyone know what the story is on these? Were they a "big truck" thing? Most 66s I've seen don't have framed side glass. Anyone else have a post-1964 pickup with framed side windows? Just wondering. Thanks.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 06-23-2015, 10:48 PM   #2
hotrod66
hotrod66's Avatar
Re: Metal-framed side windows... what years?
My 65 3/4 ton has them as well ,from what I'm told it was a option. a lot of the large trucks have them such as the c 60s I have noticed.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 06-23-2015, 11:09 PM   #3
MisterC
MisterC's Avatar
Do those windows require different felt or weatherstripping? I love the look of them.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 06-24-2015, 12:00 AM   #4
perro13
perro13's Avatar
I've see a few of the bigger trucks with them, I think I even have a pair.
perro13 is offline   Reply With Quote
Old 06-24-2015, 01:13 AM   #5
C/10 King
C/10 King's Avatar
My old 66' had them,...... and so did the pumpkin, but I can't find a pic with the Pumpkins windows half way up.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 06-24-2015, 08:16 AM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
Can you still get them repop?..i have never sen them....
Do they take a different felt?
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-24-2015, 08:31 AM   #7
jbgroby
jbgroby's Avatar
My original truck '60 came with chrome ones (I still have, will probably part out to someone) I used a standard black pair on my doors.
jbgroby is offline   Reply With Quote
Old 06-24-2015, 09:01 AM   #8
1963c-10
1963c-10's Avatar
The metal framed glass was laminated.
The non framed glass was tempered or safety glass.
And yes, they require a different beltline kit for the doors to accommodate the difference in thickness. I converted my 63 stepside to the framed glass.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-24-2015, 10:58 AM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Wow, I never knew there was these two options. All the ones I have owned did not have the frame and I can't recall seeing any with a frame. Now I'll have to start paying attention.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-24-2015, 11:57 AM   #10
oem4me
Option code A09 laminated glass. Includes metal frames.
See lower left of page below.
I see laminated glass listed as optional on the sheet for 1966 (below) and 1963, but not on the 1960 sheet. ? Did all trucks in 1960 have laminated side glass?
Old 06-24-2015, 12:39 PM   #11
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
i have a set of those on my truck.
Sick5 is offline   Reply With Quote
Old 06-24-2015, 02:12 PM   #12
1963c-10
1963c-10's Avatar
Not sure, but I can add that my framed glass came out of a 1961 St. Louis truck, short fleet 6cyl/3sp if it helps any. Mine were also black. The only chrome ones I've seen were 1960 personally, but I'm not sure if they were available chrome in other years.
So far from what I've gathered here and seen personally
1960 - chrome
1961 - black
1966 - black
Maybe some others will chime in and we can add to the list of what was available.
And a few pics of the conversion I did on my 63 with the 61 framed glass. I have pics somewhere on the build thread of the glass out prior to install if needed.
Old 06-24-2015, 06:44 PM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
late 62 for the switch to tempered glass I think, after that it was an option to get the laminated glass. my 64 1/2 ton has the option listed on the build sheet, I think it was a $35 upgrade! I will have to look next time I am out there.
I had heard that the laminated glass was common in the big trucks 63-66, the only other laminated set I have seen in the 64-66 was in a 3/4 ton gmc.
Old 06-24-2015, 10:14 PM   #14
sodly
sodly's Avatar
Good info, OEM! Sounds like we have our answer. Now... what's the difference between tempered and laminated glass? What's the advantage of one over the other?
WANTED:
Old 06-24-2015, 11:11 PM   #15
jtrichard
laminated will crack ( it is the same as windshield glass) "but still useable" tempered shatters "BIG hole in door not nice in winter until you can find a new one".......the laminated any glass shop can cut you one ......the tempered on has to be FOUND USED/ ORDERED for the truck OR cut and sent out to get tempered
jtrichard is offline   Reply With Quote
