Old 06-24-2015, 12:12 AM   #1
ivorton74
ivorton74's Avatar
Cruise control retrofit
I'm tired of keeping my foot on the gas pedal on a long cruise....I guess I'm spoiled now lol. So I want to put cruise control in my 74 but I need to know what I need and how to wire it up. I need to know what switch will work with my truck. Also my speedometer doesn't work I'm not sure how that's going to work out. My truck has the factory non-tilt column...don't know if that matters.
Truck has a '99 5.3 with an '02 4l60e.
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 06-24-2015, 01:24 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Cruise control retrofit
On a '99? Thats still DBC so you'd actually need the cable cruise box-thingy that physically manipulates the throttle cable. The wiring normally in the stalk can be done without a stalk, but it involves adding a pair of momentaries and a toggle do serve the same functions that the all-in-one stalk provides. The setup usually also wires into the stop switch to provide a "cancel" function and for safety reasons.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-24-2015, 03:37 PM   #3
MalibuSSwagon
http://chevythunder.com/cruise_control_system.htm
MalibuSSwagon is offline   Reply With Quote
Old 06-24-2015, 11:28 PM   #4
ivorton74
ivorton74's Avatar
wow there's a lot to know when ur doing this...kinda overwhelming
Old 06-25-2015, 08:40 AM   #5
mej005
I used the Dakota Digital stalk and had to use relays to reverse the way it switched. Here is a good thread to read through that has wiring diagrams and a lot of information.
http://67-72chevytrucks.com/vboard/s...cruise+control
One thing I did run into is that Chevy used at least two different length cruise cables. The first one I bought at the wrecking yard was too short from the bracket to the throttle body, it wasn't much but it would not work. Wiring was fairly simple, but took me about three hours to hook everything up. I have about $65 in my setup and love it!
mej005 is offline   Reply With Quote
