A C Control
I replaced the fan switch, relay and resistor on my AC. On the inside of the heater box duct work, there is some kind of control. It is about the diameter of a nickle, and is connected to the middle lever of the heat/ac control panel. It has a plunger on one end, which I assume controls something on the compressor. The other end has 2 spade type plug connectors. What is it and who has it?
Thanks, TF |
I assume you mean the one on the back of the air duct box, if so it is the button switch and it switches the power to the compessor and is activated by the cam piece on the back of the flapper box being turned when you select A/C on the controller
