Speaker placements
Hi
Just wondering where can I install speakers in my 72...kick panels or doors. Thanks Posted via Mobile Device |
Re: Speaker placements
You can install them in either place. It is easier to run the wires if you put them in the kick panels, plus you don't have to cut up your doors!
You buy the kick panels that are molded for speakers. No cutting required.
#5 | |
I think the sound is better and install cleaner with them in the door PANELS, not the bottom of the door. Here is my install:
http://67-72chevytrucks.com/vboard/s...d.php?t=659786
#7 | |
or do i need to remove them...
Unless there is something else over your kick panels, they are just steel integrated into the sheet metal, nothing to remove.
