Rack/pinion problem
I sectioned my cross member two inches. Another member said he used a rack from a 00 Dakota. I picked one up and it lays on top of the lower control arms and about a half inch from the pulley
![]() Join Date: May 2014
Re: Rack/pinion problem
Someone who knows more will probably answer this but don't you need a notch in your frame to clear the R&P?
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
move it infront of the pulley?
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
im using a rack from an 88 thunderbird. i sectioned the front of my cross member back about an inch to line everything up
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
