Old 06-24-2015, 11:27 PM   #1
rickcdewitt
rickcdewitt's Avatar
72 k20 lsx exhaust manifolds
hey guys i know theres lots of info on stock manifolds but i seem to be missing definitive examples for 4x4 frames. tbss? 98 camaro? 2010camaro? really don't want to cut my frame! 6.0l nv4500 if that helps. appreciate links to 67-72 4x4 lsx builds w/manifolds. lurked for a couple years and getting close to swapping.this seems to be one of the last questions for me.thanks!
rickcdewitt is offline   Reply With Quote
Old 06-25-2015, 12:12 AM   #2
rickcdewitt
Re: 72 k20 lsx exhaust manifolds
it seems the tbss didn't work for wasted income on his pops truck?72 truckman used 05 1500 manifolds? i guess the height of the motor in the frame comes into play as well as distance from firewall?
Old 06-25-2015, 06:06 AM   #3
engairuph
I used the Ls3 manifolds from Camaro 2010 and no cutting, plenty of space.
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 06-25-2015, 06:22 PM   #4
MalibuSSwagon
I used a passenger side truck manifold from a 2006 Silverado (no EGR bump) and the drivers side one would have worked except the outlet dumped right on my external slave cylinder. They get pretty close to the frame but they fit.
MalibuSSwagon is offline   Reply With Quote
Old 06-26-2015, 02:14 PM   #5
Nitis
Nitis's Avatar
Check the 4x4 build threads. There's a couple in there.
Joey Durango also comes to mind.
What crossmember are you using or you building your own?
Nitis is offline   Reply With Quote
Old 07-01-2015, 01:34 AM   #6
rickcdewitt
thanks for the replies guys! i'll probably cut and weld my crossmember after the motor and trans play nice with the firewall and diff.i looked up joey durango but didn't find where he settled on a manifold. i was thinking of the ls3 manifolds but it seems the bolt pattern won't match my 2000 6.0l after looking at pics? i'm not totally opposed to shorties but i'de like to find a magic bullet for this.
Old 07-01-2015, 07:26 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
I used 2010+ Camaro manifolds but made my own mounts...
http://67-72chevytrucks.com/vboard/s...d.php?t=530623
Rich
1972 K5 Blazer CST Click HERE
Old 07-03-2015, 01:46 PM   #8
rickcdewitt
Originally Posted by rickcdewitt View Post
i was thinking of the ls3 manifolds but it seems the bolt pattern won't match my 2000 6.0l.
sorry it was late and this is my first chevy!
mcmlxix thats a sweet k5! now to find some camaro take offs..
Old 07-03-2015, 02:03 PM   #9
rickcdewitt
just found some good 2010 camaro manifold pics in jamesjones thorley ls swap headers thread.
Old 07-03-2015, 03:17 PM   #10
Nitis
Nitis's Avatar
Just FYI not sure if you have caught this or not but you can't compare any 2wd stuff because it all depends how you build or install your crossmember
2wd guys can just put adapters in 4x4 more involved
Old 07-03-2015, 04:52 PM   #11
engairuph
How true that is. It has taken me almost two months to find exhaust I would not have to cut or trim the frame.
Ralph L. Jasper
13 GMC Ext cab
MAI
Interior shop
Old 07-06-2015, 05:22 PM   #12
robgmaddux
Junior Member
robgmaddux's Avatar
I used 1998 f-body manifolds. I cut the stock 4x4 cross member and plated it for oil pan clearance.
My build thread! http://67-72chevytrucks.com/vboard/s...d.php?t=665907
robgmaddux is offline   Reply With Quote
Old 07-07-2015, 12:59 AM   #13
mcmlxix
mcmlxix's Avatar
going to be hard to find now ... but the 2004 - 2006 Pontiac GTO manifolds are another option....
Rich
Old 07-08-2015, 02:21 PM   #14
rickcdewitt
yeah,just a bit frustrating! my truck started as a c10 then c20 now getting towards a frame off k20.how did that happen for a dump run, john deere pulling work truck?
those gto manifolds look like they might be close to most mounts.but are almost iron shortie headers.
Old 08-02-2015, 12:15 AM   #15
rickcdewitt
so the 2010-2015 camaro manifolds fit great, pics in my build
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
