Old 06-25-2015, 08:58 PM   #1
gdavis
gdavis's Avatar
308 rear end
REAR END IS SOLD PENDING PAYMENT TO MRWELD
I have a rear end 308 ring and pinon and all hardware for sale. asking 125.00 plus shipping. I took it out of the rear end housing
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 06-25-2015, 09:26 PM   #2
jdalexa84
Re: 308 rear end
Just the ring and pinion or is the carrier included?
what rear end is it for? 12 bolt? Do you have pictures
jdalexa84 is offline   Reply With Quote
Old 06-26-2015, 09:26 AM   #3
gdavis
gdavis's Avatar
Re: 308 rear end
Everything except the housing. It would cost too much to ship the housing so I got read of the housing as junk. carrier included
Check out Patches
Old 06-26-2015, 11:46 AM   #4
Steve Cole
Re: 308 rear end
Hey George,
quick question, will this just bolt in or will adjustments/ setup be needed? I.e. backlash adjustments , etc.
Thanks,
Steve Cole is offline   Reply With Quote
Old 06-26-2015, 12:52 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
Re: 308 rear end
Steve, you will need to set up the preload on the side carrier bearings and the pinion bearings. All that is required on the pinion is a new crush sleeve, but the side bearings use shims. If you are not replacing the bearings, you should be able to reuse the shims that were there. I would not advise reusing the crush sleeve though. Oh, and a new pinion nut or some loctite on the existing one.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-26-2015, 01:55 PM   #6
gdavis
gdavis's Avatar
Re: 308 rear end
Originally Posted by Steve Cole View Post
Hey George,
Thanks,
thanks 70stovebolt for answering Steve's question, now I don't have to.
Check out Patches
Old 06-26-2015, 02:03 PM   #7
Steve Cole
Re: 308 rear end
Thanks for the quick answer! Is something that can be done by someone who has never done it before?
Old 06-26-2015, 03:02 PM   #8
mrweld
mrweld's Avatar
Re: 308 rear end
I want the gear and carrier, PM sent..
mrweld is offline   Reply With Quote
Old 06-27-2015, 07:46 PM   #9
gdavis
gdavis's Avatar
Re: 308 rear end
rear end is yours sending you a PM
Check out Patches
