Old 06-25-2015, 09:46 PM   #1
Chevy Fan Always
Chevy Fan Always's Avatar
Sway bar
I am thinking of adding an original sway bar to my C10. Does anyone know if this improves the handling enough to justify the work. Also, if they were factory installed they were riveted, do I have
To drill out a rivet on the frame and bolt it where the rails meet the front x member?
Chevy Fan Always is offline   Reply With Quote
Old 06-25-2015, 11:47 PM   #2
Custom/Ten
Custom/Ten's Avatar
Re: Sway bar
Yes it's worth it, and yes you have to grind/drill out the rivets. I used bolts and lock washers. Mine was a kit from cpp for 120$ and came with everything I needed. Came with stock height and lowered brackets. Ive heard really low truck have had probs with the cpp kit. Whatever kind you get you will feel a difference. Also it's not much work, takes about thirty min.
Custom/Ten is offline   Reply With Quote
Old 06-26-2015, 12:09 AM   #3
mike16
Re: Sway bar
you can bolt the sway bar in and remove it if origonality becomes an issue. you can also rivet it in too. there are vendors that sell rivets . I know they advertise in corvette tech forums but cannot find the actual one that sells them.
hunt for them and you will find them.
a front sway bar dramaticaly improves safe handleing; a rear one somewhat less so.
mike16 is offline   Reply With Quote
Old 06-26-2015, 11:06 AM   #4
chopnchaneled
chopnchaneled's Avatar
Re: Sway bar
If you can go with one off at least a C20. direct fit.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 06-26-2015, 11:26 AM   #5
Ole Greenie
Ole Greenie's Avatar
Re: Sway bar
As mentioned above, I completely agree. This is perhaps the best upgrade I have done to the old truck for the money spent. 2 hour install with a grinder. I also used the CPP sway bar. The handling improvement was tremendous!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 06-26-2015, 11:33 AM   #6
leftybass209
leftybass209's Avatar
Re: Sway bar
Regarding suspension the sway bar is easily the most drastic improvement you can make on these trucks. Some will say you HAVE to get the large sway bar, but for normal driving conditions you'll notice a bigger improvement going from no sway bar to the stock diameter, than you will moving from the stock diameter to the beefy 3/4 or 1 ton bar from the 73-87's,
leftybass209 is offline   Reply With Quote
Old 06-26-2015, 11:58 AM   #7
michael bustamante
michael bustamante's Avatar
Re: Sway bar
theres actually a complete setup for sale now in the for sale section
1967custom
michael bustamante is offline   Reply With Quote
Old 06-26-2015, 01:08 PM   #8
Lees68GMC
Lees68GMC's Avatar
Re: Sway bar
My truck 68, had no sway bar upfront. After looking over the stock set-up went with this Addco bigger bar, also wider so different leverage points applied to the lower control arms. Also even though the control arm mount had a bolt, we both bolted and welded it.
My truck thinks it's a Camaro, always has.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 06-26-2015, 01:57 PM   #9
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Sway bar
Best bang for the buck you can do to a 67-72 and the difference in handling will amaze you. Any front sway bar for a 73-87 Chev/GMC C10,20 or 30 will fit. The biggest factory one was a 1 3/4 inch diameter and that is the one to get. They usually came a real heavy duty C20's or on the C30's. If your truck does not have one now after you install one you will notice the difference in handling immediately.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-26-2015, 04:17 PM   #10
Chevy Fan Always
Thanks for all the good advice, I now have stock ones purchased for both trucks!
Old 06-26-2015, 05:15 PM   #11
Redline novdog
Redline novdog's Avatar
Re: Sway bar
I put the wimpy stock bar on my '67,best money spent. You will feel the difference.Good choice.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 06-27-2015, 05:08 PM   #12
hayhauler71
hayhauler71's Avatar
Re: Sway bar
Add a rear sway bar and be twice as happy
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 06-28-2015, 01:01 PM   #13
dell72
Re: Sway bar
I added a front sway bar of a 73-87 truck to my 69 and later added a rear sway bar. The rear sway bar made the most noticeable difference.
dell72 is offline   Reply With Quote
Old 06-28-2015, 06:44 PM   #14
Crushkrew
Crushkrew's Avatar
Re: Sway bar
We just added the front cpp kit to the 71 with ece 4/6 drop....we used the included lowered brackets....had to shorted the end link spacer to clear the tie rod arms....
Night and day difference in handling...rear kit going in next...
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510
Crushkrew is offline   Reply With Quote
