09-05-2003, 04:38 PM | #1 |
73-87 4x4's
i'm trying to decide the amount of lift i want for my 81 short box chev.... so i'll post this here; let's see all those lifted 4x4's, everything from mild to wild.... i want to see it all.
1981 GMC Sierra 1/2 Ton SWB 4X4 |
09-05-2003, 05:32 PM | #2 |
this is from the 4x4 post on this page
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
09-05-2003, 08:27 PM | #3 |
user # 2756
My 85 I had to sell
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
09-05-2003, 09:09 PM | #4 |
'75 frame, '83 cab, '88 clip, 6 inch suspesion lift, 3 inch body. 35x16x15 boggers on 10 inch wide white spokes. Needed longer brake lines, spacers for the sway bar, drive shaft binds sometimes, lengthen the shifting linkage cause of the 3 inch body lift, raised steering arm needed, probably also need a dropped pitman arm or a drag link with a correction.
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208. |
09-06-2003, 11:36 AM | #5 |
that 85 what size tires and lift is in it.....i have 33's on mine with no lift......keep'em coming guys
09-07-2003, 11:54 AM | #6 |
user # 2756
4" rugged trail w/ 35" mud kings on 15x10 white wagon wheels.
09-07-2003, 06:25 PM | #7 |
'86 with 8" lift. 2" body +6" suspension. No blocks in back.I used a set of rear spring front perches off a 74 blazer. gave perfect 4" lift plus the stock springs with a 2" add a leaf..It put the pinion angle perfect..
Dana 60 with 4.10's and powerlock up front, withBlackbird's Custom Trucks crossover steering 14 bolt with 4.10's and a detroit plus th a set of Blackbird's Custom Trucks rear disc brake kit and traction bars..Its just got a little 355 in her now..Just waiting for winter and the mud racing to slow daown to toss in a 476.. Oh yeah those are 36" swamper tsl sx. Only rub when i land from jumping..
Support The Board |
09-07-2003, 11:43 PM | #8 |
81 Chevy short bed 4X4 4 inch suspension lift with 33x12.5x15's fixing to be changed out for 255-85-16's Can't seem to make it post so here's the link
http://www.hunt101.com/showphoto.php...=500&password= |
09-09-2003, 03:18 AM | #9 |
keep them coming
