1963 Horn Location
Sorry, but the search did not return what I am looking for. The horn relay on my '63 went out. This morning as I was removing it, I noticed that the wire running to the horn from the relay also branched off and went into the wiring harness. I suspect that it should go to another horn located somewhere else, but I don't have that other horn and I don't know it's correct location. The horn that I have is located on the drivers side directly over the horn relay location. The current horn is labeled Delco-Remy type S, model 427 12 volt. Anyone know if this is the correct horn and if it is a high or low tone?
Thanks, Hugh |
Re: 1963 Horn Location
Its the correct horn and in the correct location. Hi or low note will depend on which way the spiral runs.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Low note which is the most common spirals clockwise, high note spirals counter clockwise
Also....if what I've read is correct off the 67-72 threads, the 67-72 guys think the hi note wasn't in production until around 69.
So, this '63 should only have one horn?
Thanks, Hugh |
Correct.
Heres a pic when I reinstalled mine in the factory location.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
![]() ![]() ![]() ![]() [IMG] ![]() Not a great pic but you can see it in place.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 06-26-2015 at 07:55 PM. |
