06-26-2015, 11:05 AM | #1 |
Thoughts on this ECM location
High hump in low hump cab
http://67-72chevytrucks.com/vboard/a...1&d=1435330982 ECM under hump http://67-72chevytrucks.com/vboard/a...1&d=1435330982 Heat issues? Carpet fit? |
06-26-2015, 02:03 PM | #2 |
Old member
Re: Thoughts on this ECM location
Nothing wrong with it but why not just go under the seat with it. Save the hump panel.
06-26-2015, 02:24 PM | #3 |
I am with Andy. Plus easier to get to under the seat.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
06-26-2015, 05:53 PM | #4 |
Post Whore
Ditto..under the seat..not a bad idea though..wouldn't be nothing wrong with that but I would put some insulation under it because that will get pretty warm from the trans heat.you would have to use "high" hump carpet
06-26-2015, 05:56 PM | #5 |
The floor under my seat is well represented by audio equipment so I mounted mine in the upper left corner on the inside of the fresh air channel behind the dashboard. The bottom hangs slightly below the dashboard and is hidden behind an a/c vent.
06-26-2015, 07:04 PM | #6 |
meowMEOWmeowMEOW
I moved mine from my inner fender, to on the passenger side inside-footwell area. Unseen from outside the truck, no real cost to passenger legroom, unless they have size 20 feet.
06-27-2015, 08:09 AM | #7 |
Thanks for the ideals
06-27-2015, 08:49 PM | #8 |
Old member
Mine is in the glove box. I cut the card board part for the connectors to fit into the ECU and hold it tight up against the back part of the box. I have room for small stuff.
06-29-2015, 12:29 PM | #9 |
I installed mine in that basic area My gas tank is removed so it is all the way at that back wall. When I first did mine I was using a tuner and had to send the pcm back and forth (just return my old one) and this became a pain as it was not real convenient to get to. Keep that in mind of course once it is done you really don't need to swap much except for changes. I am now tuning my own so I can just plug into the obdii port and not worry where the computer is.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-01-2015, 07:26 AM | #10 |
I made a bracket to mount it at an angle behind the glove box and trimmed the cardboard liner so it can still be used as a glove box.
07-01-2015, 10:24 AM | #11 |
ls64 I like that , it is a very clean location and install.
