Old 06-26-2015, 01:25 PM   #1
Lugnutz65
Lugnutz65's Avatar
Radiator core support grommets 1965 C10 - know any vendors?
I've checked with the major vendors and I can't seem to find the grommets that protect the wiring that passes through the radiator core support. I might need to make my own but would rather buy. I'm referring to the grommet on the DS where the headlight wiring passes through. There is another grommet on the PS where the red power wire passes through. Maybe my memory is bad but I'm pretty sure grommets were there. Any vendors? What do other folks do to protect the wiring in these areas? Thanks
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-26-2015, 01:57 PM   #2
1963c-10
1963c-10's Avatar
Re: Radiator core support grommets 1965 C10 - know any vendors?
The driver side......grommet is built into the harness. When you plug the harness in, the part that goes through the grill support has the grommet attached. The grill harness then plugs into that.
On the pass side....I used a grommet from home depot in the specialty hardware section.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-26-2015, 02:02 PM   #3
Lugnutz65
Lugnutz65's Avatar
Thanks. That does jog my memory. I have yet to open my AAW sub-kit with the headlight wiring. I'm hoping the AAW kit is set up that way. I'll look for a grommet to fit the PS hole. The task of wiring a truck is full of surprises.
Old 06-26-2015, 02:11 PM   #4
1963c-10
1963c-10's Avatar
I still have some grommets left. Let me see if I have any large enough to fit the pass side. Will check tonight when home.
Old 06-26-2015, 02:19 PM   #5
Lugnutz65
Lugnutz65's Avatar
Thanks. I just might swing by HF on my way home and pick up a multi-pack they sell in a box. Another option would be to slit a piece of small size vacuum line down the side and then roll it into a circle the right size for the intended hole.
Old 06-26-2015, 02:21 PM   #6
1963c-10
1963c-10's Avatar
the grommet would work better as it has the edges to hold in place. I picked up an assorted pack also.
Old 06-26-2015, 02:31 PM   #7
1963c-10
1963c-10's Avatar
The driver side grommet can be seen on this forward harness....on the right next to the voltage regulator plug. red/green wire round plug
Old 06-26-2015, 11:20 PM   #8
spookylynx
spookylynx's Avatar
I've always had good luck a Ace Hardware, or something similar in your are that has the huge selection of nuts bolts and pieces parts. You know, the random drawer isle with all the spacers washers, plugs, blah blah... Ive almost always found something that will work.
spookylynx is offline   Reply With Quote
