Old 06-26-2015, 02:00 PM   #1
Popcorn W
Popcorn W's Avatar
64 Light Green paint. Any rattle can that's close?
I've looked at Home Depot, Lowes & Wal-Mart with no luck. I'm surprised there's nothing even close anywhere.
I just want something fairly close so I can paint the bottom back of my cab and the bed headboard before I put it back together.
My build thread:
Project Moonshiner Bagged & Z Frame 63
http://67-72chevytrucks.com/vboard/s...d.php?t=659205
"I love the smell of grinding metal"
Popcorn W is offline   Reply With Quote
Old 06-26-2015, 02:38 PM   #2
65chevysub
65chevysub's Avatar
Re: 64 Light Green paint. Any rattle can that's close?
This is just a suggestion. I went to my local paint store with the formula/paint color, and had them make a pint, then put it into spray cans for mine when it was light Green. It was about $5 per spray can at the time plus the cost of mixing the paint. Worked great, as I painted my rims to match the body.
65chevysub is offline   Reply With Quote
Old 06-26-2015, 03:26 PM   #3
HappyHooligan
HappyHooligan's Avatar
http://www.homedepot.com/p/Preval-9-...-267/202533738
Check out Preval sprayers, can use what ever paint you want in them. we use them for touch ups on aircraft at work all the time.
I might have re-appropriated 1 or 2 for home use
Hooligan
The Green Hornet
1960 Apache 10 Long Fleet - Driver and Work In Progress
The Death Star
2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side
HappyHooligan is offline   Reply With Quote
Old 06-26-2015, 06:56 PM   #4
65chevysub
65chevysub's Avatar
Hooligan
Man I like this sprayer. Any special tips to using one of these? Seems just like a rattlecan
Old 06-26-2015, 07:48 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Because your using a normal finish, the paint will still abide by the chemical makeup and drying times of normal auto paint. It won't "feel" like spraypaint coming out of the sprayer, nor will it flash dry the same. BUT if your using it for touchup and small parts matching, it will be fine. Just keep in mind that it still has the properties of regular auto paint.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-26-2015, 07:53 PM   #6
HappyHooligan
It paints pretty much like a regular spray can.
I've used several types of paint in them cool part is you can mix up as little as you need.
Couple of times I've had to add a little extra thinner but that just depends on your paint.
Hooligan
The Green Hornet
The Death Star
Old 06-26-2015, 08:50 PM   #7
Popcorn W
Popcorn W's Avatar
Thanks. I've seen them around for quite a while but never used one. I guess the main thing was I was trying to avoid a trip to the auto body supply store.
My build thread:
Old 06-27-2015, 03:07 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've seen them at all the Napa's, a few Farm-Fleet places, Amazon Prime! and others. They are REALLY common. Even Ace Hardware has them by me.
Old 06-27-2015, 03:43 PM   #9
factorystock
factorystock's Avatar
You pay a little more, but you'll be happier with the results. Light Green is paint code 503.http://www.automotivetouchup.com/spr...t_matched.aspx
factorystock is offline   Reply With Quote
Old 06-27-2015, 09:24 PM   #10
Popcorn W
Popcorn W's Avatar
Thanks. Lots of "purists" here I guess. The area between the rear cab and headboard on most pickups isn't usually even painted in most color changes because you can't even see it. I wasn't looking for Barrett-Jackson quality, just something close so I can get on with the build.
My build thread:
