Old 06-26-2015, 03:31 PM   #1
BRASSHEAD
BRASSHEAD's Avatar
soft ride
Ever since I bagged my truck it rides rougher than I think it should. I am running hydraulic shocks on the front and back. Just thought I would ask what you guys use and what is the softest riding shock for the money. the truck is a 66 short stepside. Thought about pulling the shocks and take it for a test ride to see if there is any difference.
BRASSHEAD is offline   Reply With Quote
Old 06-26-2015, 04:00 PM   #2
joedoh
joedoh's Avatar
Re: soft ride
most times bagged guys use shocks that are too short and are made for short travel springs. you want a gas charged long travel shock. I have shocks from a jeep rubicon, 9-10" travel and gas charged, my ride is pillow soft even a couple inches off the ground.
make sure you have the right bag too and are running the right air pressure. your driving pressures should be 80-90 for the front and 30-60 for the rear. if they are higher than that, the spring rate is also very high.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 06-26-2015, 04:51 PM   #3
BRASSHEAD
BRASSHEAD's Avatar
Re: soft ride
to get a decent ride I am running around 60psi in the front but I have to watch for dips in the road, sometimes it will bottom out. the long stroke shock sound like a good idea would just need to extend my shock mounts.
Old 06-26-2015, 06:19 PM   #4
cheessee
Re: soft ride
How did u set it up in the rear? A lot of times people set it up and it rides rough what size/brand bags
1963 GMC swb sbw 5.3/4l60e porterbuilt
From middle Tennessee
60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details..
cheessee is offline   Reply With Quote
Old 06-29-2015, 10:11 AM   #5
BRASSHEAD
BRASSHEAD's Avatar
Re: soft ride
Changed the front shocks out this weekend. Went with a set from a 94 F150 because they had the right length and had the stud mount on top which made it easier to make new upper mounts. Big improvement on the ride quality, thanks for the help!
