Old 06-27-2015, 12:13 PM   #1
mrblalock66
Headlight conversion
Is it possible to convert the round headlights in my 79 K5 to the rectangle ones that are in the 1980 without a ton of work?
mrblalock66 is offline   Reply With Quote
Old 06-28-2015, 10:28 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Headlight conversion
Should just be different buckets, reuse the adjusters and spring.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-29-2015, 07:17 AM   #3
mrblalock66
TY I put this question on the truck section and was told I would need to change out the core support as well. Any truth to that or did you do exactly what you told me to do? I do know the supports differ in many ways.
Old 06-29-2015, 08:04 AM   #4
Hammered 77
Hammered 77's Avatar
Back before I replaced my entire front end with a 91 suburban on my 77, I put the sq head light in place of the round. I just replaced the buckets and cut the door opening to accept the sq lamp. So I would think you could swap the other way around with just buckets and headlight doors.
Rick
Hammered 77 is offline   Reply With Quote
Old 06-29-2015, 10:07 AM   #5
68Timber
68Timber's Avatar
I wondered if the core support would be different for the wider buckets/lamp. You should still be able to make it work pretty easily with a little trimming.
John
74 Honda Z50 build
